Results 1 to 10 of 10
Thread: Opening Pool for Season and now what..??
    Had to fill pool up at least 2/3 with fresh water this season...
    pool has been circulating for 24 hours-- since I had to fill with a lot of fresh water what are my next steps...
    1. Can I go ahead and test stabilizer? or wait another 24 hours? ( I am pretty sure there isn't a whole lot in there...last year I kept around 40)
    2. I did test Chlorine and it was at 0 and CC was at 0 (do I need to add a little bleach to keep it from going green until I get stabilizer right?)
    3.PH is around 7.6 ( I tested just now)
    I didn't test anything else as I normally don't have any other issues-
    Just need a little advice- I do have stabilizer and bleach on hand...
    Thanks in advance
    21 ft Round Dough Boy
    3/4 horsepower Dough Boy PowerPak II pump
    Vinyl Liner
    baqua goo convert
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Opening Pool for Season and now what..??
    1. Can I go ahead and test stabilizer? or wait another 24 hours? ( I am pretty sure there isn't a whole lot in there...last year I kept around 40) If its been running a few hours go ahead and test.
    2. I did test Chlorine and it was at 0 and CC was at 0 (do I need to add a little bleach to keep it from going green until I get stabilizer right?) Yes, get some chlorine in there now to keep it clear.
    Are we dealing with a pool that will need a SLAM?
    Support the site
    What is SLAM? shock level and maintain?
    The water is clear and we converted from back-goo about 5 years ago
    and how much bleach? do you think I should add?
    I just put in stabilizer as well in a sock in front of skimmer
    Normally when I open I have at least a little bleach in it, but where we had to refill 2/3 I am not sure
    Vinyl Liner
    baqua goo convert
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by bearclaw20 View Post
    What is SLAM?
    How did you determine how much stabilizer to put in the sock? I'm hoping you used Pool Math to calculate the amount. You can also use Pool Math to calculate the amount of bleach to add.
    A SLAM is a continuous process of adding chlorine to a pool until the pool is completely clear/clean. SLAM Process.
    You would need to SLAM if you oped the pool to cloudy and/or green water, high chlorine consumption or any other issue related to organics in the water.
    Support the site
    OH yes I use the pool calculator for everything...I added 53 oz by weight of granular stabilizer...to get it to 40- since it was at almost non in there since I just tested-
    Based on the calculator and CYA chart I would need to bring shock level to a 10 with Chlorine? since my stabilizer is 20 or less??
    That would require 207 ounces of 6% bleach..however, I have bought the wall-mart brand bleach and it says it is concentrated 8.25 Sodium hydrochloride and 91% other??? do I need to adjust bleach % in calculator? if so that makes the amount 151 ounces?
    Is it best to go ahead and bring FC up to 10 even though
    is just now dissolving? I am figuring bleach will burn off tomorrow in sun but some it better than non at least until the stabilizer gets fully dissolved in the next 48 hours?
    Vinyl Liner
    baqua goo convert
    May 2014
    Franklin, NC
    9,184
    Yes, in the yellow FC area change the box to reflect 8.25% and the drop down to say 121 oz bottle.
    Tomorrow your shock level will go up as you assume 40 CYA then.
    Support the site
    Thank you! I get way to stressed each year when we open the pool- you guys are a life saver-
    Should I test CYA tomorrow evening or wait another day? just test FC/CC tomorrow and top back up to 10 until I know for sure what the CYA is?
    Vinyl Liner
    baqua goo convert
    May 2014
    Franklin, NC
    9,184
    No need to test the CYA for a week, it can take that long to register on teh test. Just assume it's 40 starting tomorrow and raise your shock value up using the FC/CYA chart.
    Support the site
    Thanks
    Hoping this East TN warm weather lasts a while..we hit a record today of 89
    Wahoo!!!
    oh one more thing...was the bleach right? I feel like the ingredients are different?
    Vinyl Liner
    baqua goo convert
    May 2014
    Franklin, NC
    9,184
    Thanks
    Wahoo!!!
    Nope, it should be GreatValu 8.25%. you just don't want the scented, splashless, flavors or any other funny things - just bleach.
    Support the site
