Thread: Looking for my 1st cleaner
    Just wanted to know the major differences between the pressure cleaners ( I have a connection for that), vs the Robot type cleaners. Also, which one is generally better for an in ground pool 20 x 40.
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Looking for my 1st cleaner
    Isolated Spa - 345 Gallons
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I have the Polaris 280 on a timer with a pool sock in the net bag and it works great. I run it 2 hours at night, and I have a lot of trees.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I have a 20X40 and a Polaris 280. It came with the pool/house. I was wondering how good it really was until the leaves started falling last year. That thing will flat out clean up a pool. I need to get a skimmer sock or a finer bag for it so it does better at getting the finer particles up, but it does pick up most everything. What it doesn't pick up gets put back up in the water so the filter can catch it.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jul 2007
    Suwanee, GA
    528
    I too have a 280 and it does clean the pool well. All larger stuff ends up in the bag, including small toys and sometimes even goggles. Smaller particles and dirt are continuously blown around until they end up in the filter.
    What I wish it would do better, which a robot would do, is sweep the sides of the pool I've noticed over the years that the walls are showing a bit of discoloration due to not being swept as much. I can scrub it off with a stainless bristle brush, but that is a pain.
    Still given my choices, I'm fairly lazy and don't want to have to manage a robot. The 280 stays in the pool all the time, runs on the timer and just keeps it clean.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
