Got the pool opened, it was fairly green but all debris are out and the water is clear with a green tint. First test results:
FC = 0
CYA = 0
TA = 80
CH = forgot to test. Fiberglass pool, I will adjust if I need to
PH = 7
So should I start by adding CYA to get it to about 30ppm and then add enough bleach to begin the SLAM process? Or start with PH?
FC = 0
CYA = 0
TA = 80
PH = 7
