Thread: ProTeam Mustard & Black Magic use?
    May 2012
    Oconee, Georgia
    82
    I just checked a friends pool he needs to shock. His fav level is 0 and cc was 2. The problem is his cya level is somewhere around 100 first time I gotv90 second time 100. He is using a salt chlorinate. It would take a lot of bleach to shock this pool. Has anyone tried ProTeam Mustard & Black Magic? Partial drain to lower cya is not possible.
    Ph 7
    Fc 0
    Cc 2
    Ta 70
    Ch 230
    Cya 90-100
    18'x36' inground vinyl liner.Pentair Sand Filter SD-60, Pentair EastTouch IC40 Salt Gen.
    Pentair Legend Cleaner. Pentair SuperFlo 1 hp pump. Color LED pool light.
    Taylor K-2006 (FAS-DPD) w/ SpeedStir. Pool Built October 2013.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: ProTeam Mustard & Black Magic use?
    Anything but bleach is hocus pocus, hokum, snake oil, astrology, ponzi scheme, etc. etc. The only solution is more bleach. If partial drain is not acceptable (ANYTHING is possible) then that's the option. If partial drain is not acceptable, the what about reverse osmosis treatment? You'll have to specify why partial drain is not acceptable.
    Isolated Spa - 345 Gallons
    May 2012
    Oconee, Georgia
    82
    It is hard to type on here with a phone
    He is having issues with his well.
    Don't be fooled in thinking Sodium bromide is not a good Algaecide
    Feb 2014
    Central Minnesota
    5,080
    Gotcha. Well then, the options are still there for CYA removal:
    1. Reverse osmosis. Expensive, limited availability.
    2. Drain and have a truck haul in water. Additional expense.
    3. SLAM at that very high CYA value. 39 FC (SLAM level for 100 CYA) is achievable, just takes a lot of bleach. You also need to verify by dilution testing that the CYA is actually 100 and not higher.
    Feb 2014
    Central Minnesota
    5,080
    After reading your edited posts and actually bothering to look up the contents of the product, it might be an option, with some side effects. I apologize, any time I see Dr. Fuzzy's Super Awesome Magical Bomb of Sexy Poolness... I get frothy at the mouth from being fed up with magic bullets sold at outrageous prices...
    Anyway, check this post here for details: http://www.troublefreepool.com/threa...l=1#post130785 (the Bromine section)
    Short answer is that it's like any designer drug that you're supposed to talk to your doctor about. Side effects will be there as a disclaimer.
