Results 1 to 9 of 9
Thread: Ordered the wrong chemicals
    Jul 2014
    Joplin, Mo
    33
    So being an idiot I went to amazon to order replacements for my chlorine test. I searched Taylor chlorine test reagent and ordered the biggest bottle.
    What I didn't know was there are apparently two different styles of chlorine test. R-0871 which is what I wanted and R-0001/R-0002 which is what I ordered. Is there a way I can use the chemical I received? Like a color chart I can print out to compare?
    Thanks!
    22,000ish gallon concrete pool.
    Taylor K-2006
    Sand Filter
    Joplin, Mo
    38,275
    Re: Ordered the wrong chemicals
    Nope. Sorry. Those are for the DPD test, not the FAS-DPD test.
    And the DPD test is worst of the 3 chlorine tests IMO.
    Jul 2014
    Joplin, Mo
    33
    Thanks! before I waste $30 more can you check that this is what I actually want? Does the E at the end make a difference?
    https://www.taylortechnologies.com/p...ReagentID=2445
    Taylor K-2006
    Sand Filter
    Joplin, Mo
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    If you ordered the reagent from Amazon you should be able to return it.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Quote Originally Posted by Dkoucky View Post
    That's the one... It's all the FAS-DPD titrating reagent.
    R-0871 is the .75oz bottle.
    R-0871-C is the 2oz bottle.
    R-0871-E is the 16oz bottle (I bought this one too to refill my tiny .75oz dropper).
    R-0871-F is the 32oz bottle (just found out about this one...)
    14,000 Gal IG Pool/500 Gal Attached Spa
    Pentair Whisperflow 1hp Single Speed Pump
    Sta-Rite Posi-Flo PTM-135 Cartridge Filter
    Hayward H400 Natural Gas Heater
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    No, the E is a size designation. The 0871 is the correct reagent, but you can likely find it on Amazon in that size.
    Essential Links:
    38,275
    I am not sure I would trust the remaining reagent to be any good after using 14+ oz. I mean I only use about 2 oz a year ... and the regents are only good for a couple years before they may go bad.
    Jul 2014
    Joplin, Mo
    33
    Yeah I went for the 16oz the 32oz was a good deal, but there is no way I will use that much unless my pool is just a swap all year...
    If that is the case I think I have bigger problems than my testing. A SLAM burns through the reagent last year I had to do 2 opening and after vacation. I have already started one this year but I ran our of 0871 after the first day, opened the new stuff only to find out it was bright pink which I guess means it still has FC but lord knows how much....
    Taylor K-2006
    Sand Filter
    Joplin, Mo
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You could give some to your friends Blizzle!
    Essential Links:
