Thread: I need your guidance
    wbowlin1's Avatar
    Apr 2015
    Jackson Tn
    20
    I have just changed and replumb my AG 15500 gal pool the water was cloudy by the time all the parts had come in. I added all the necessary chemicals and ran the pool overnight. The next morning when I checked my gauge on the filter it had increased by 10. Water is slightly cloudy but had extreme improvement. Should I backwash the pool or let it ride? When is the appropriate time to backwash a pool?
    2017 bahama spa - serenity cove 82x82x39 stainless steel jets, 325 gallons,plasma ozone purification system,4kW heater, 2 pumps 6bhp each, acrylic surface TFtestKits TF-100 http://tftestkits.net.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: I need your guidance
    Backwash when the pressure goes up 20-25% over the clean pressure.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    38,284
    Welcome to TFP!!
    And if the water is cloudy, you likely need to follow the ShockLevelAndMAINTAIN Process.
    Can you post a full set of test results? "necessary chemicals" is not very helpful
    Please add your pool details to your signature as described HERE as it will help us help you.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP! Does your list of appropriate chemicals match this?
    Here are some intro Pool School articles to read while you wait for your test kit
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals
    Use PoolMath to figure out how much to add.
