Results 1 to 7 of 7
Thread: 3 questions about my pool equipment
    bper's Avatar
    May 2015
    Phx, AZ
    78
    I've never known what this standpipe is a couple feet from the skimmer. It's a valve box that always has (somewhat dirty) water and a standpipe that leads to an open return port.
    Attachment 36321
    I also can't find a way to remove my return jets to clean or adjust. It looks like there may be a special tool with two slots? Same for my fiber optic lights, which have 4 slots. I want to clean them since I have mustard algae.
    Attachment 36324
    Does anyone have a solution for keeping the vac hose from getting stuck on an in-water rock feature? I usually just leave the vac in permanently but it does often get stuck when the hose gets between this rock and the wall.
    Attachment 36323
    ~13,000 gal freeform IG pebble (built 2006)
    Hayward S310T2 sand filter | Hayward Northstar 1.5hp pump
    Zodiac Baracuda G3 vac | Fiberstar 6008 lighting
    Taylor K-2006c
    38,301
    Re: 3 questions about my pool equipment
    1) Look kind of like an auto-fill, but if there is no float valve, I am think it might just be an overflow drain.
    2) I think there are tools out there for the eyeballs, not sure about the light. Should be pretty easy to make something to unscrew the ring on the eyeball.
    3) So the cleaner makes its way up onto that shelf? If so, I have no idea how to stop it from wrapping around the rock.
    bper's Avatar
    May 2015
    Phx, AZ
    78
    I have an auto-fill in another location and it's set up a little different. Just reached in there and there is water under pressure coming up from the bottom through a small hole in that center ring. When it reaches the level of the standpipe, overflows into the return. Don't see why I'd have that auto-fill in addition to one on a float valve? Maybe I will try to find the builder and ask.
    The cleaner doesn't climb, so doesn't get the step or platform. Rather the hose gets between the rock and the wall in a U shape and is unable (or takes a few hours) to escape at that point.
    Taylor K-2006c
    Vero Beach, FL
    462
    Should easily be able to make your own tool. I made one out of appropriately sized diameter pvc pipe and cut the end to leave 4 notches. Made it about 4 inches long, drilled a hole through the other end to put a screwdriver through to use as leverage to turn it. Looks like your light might have water in it.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    bper's Avatar
    May 2015
    Phx, AZ
    78
    I think it is just a second auto-fill location. Not sure why it's set up like it is, I may add a float valve to that one as well.
    Taylor K-2006c
    bper's Avatar
    May 2015
    Phx, AZ
    78
    I won't be able to get float valve in there with the standpipe taking up space. Now I'm wondering if it's just a return? I will confirm if the flow stops when I turn off my pump but right now it's running 24/7 for SLAM.
    Taylor K-2006c
    bper's Avatar
    May 2015
    Phx, AZ
    78
    So I've concluded 1) is a return. Not sure why it's set up like that
    Taylor K-2006c
