Page 1 of 4 1234 LastLast
Results 1 to 20 of 66
Thread: 1st SLAM!
    Mar 2015
    Lebanon, PA
    79
    Exclamation 1st SLAM!
    I am newbie to the TFP method.... Just opened my pool on Friday 5/8 and started the SLAM procedure,As of this am my CC is down to 1.
    I had no idea it would take sooo much bleach to do a SLAM.
    I think in all i used around 27 gallons of 8.25% to get to the CC of 1 and FC of 8 this am.
    Is this normal?I wasn't prepared for that amount ...
    Located in Lebanon,Pennsylvania.. 25,000 Gallon IG Plaster Pool Installed Fall of 2011...
    Stenner 3GPD pump
    Jandy DEV60 60SqFt DE Filter (Using Puri fiber.)..,1.5Hp Jandy Pump PMPH1.5
    Aqucal SQ 166R Heater...Polaris 9400 Robot/Cleaner
    TF-100 Test Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: 1st SLAM!
    Welcome. This is very normal. Just keep SLAMing. Can you post a full set of numbers for us please?
    Your FC is low for Slam level shock.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Re: 1st SLAM!
    25,000 gallons is a pretty good-sized pool. That amount of bleach actually sounds a bit low. I sure hope you disconnected the Nature2 and the puck feeder, or at least have them empty.
    Mar 2015
    Lebanon, PA
    79
    Re: 1st SLAM!
    Yes I stopped using tablets and took out the nature2 mineral cartridge. I also put 10,000 gallons of new water in to bring my CYA down to 40.
    Stenner 3GPD pump
    TF-100 Test Kit
    Jul 2014
    Joplin, Mo
    35
    Re: 1st SLAM!
    Looks like you need to bring it up to 16 according to the calculator: http://www.troublefreepool.com/calc.html
    Also FYI if you are using Great Value concentrated bleach from Walmart it says 8.25% but if you read further the actual yield is 7.85% available chlorine. I am not 100% but that is the # I use when I calculate.
    22,000ish gallon concrete pool.
    Taylor K-2006
    Sand Filter
    Joplin, Mo
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    Re: 1st SLAM!
    I think I used 24 gallons on my pool, I remember someone saying 2 bleach gallons every 1,000 gallons of water when I was slamming, was a "rough" estimate.
    21' x 54" AGP Heritage 12,000 gallons.
    Hayward Power-Flo Matrix SP15922S 2 Speed 1 HP
    Hayward Pro-Series S244T 24"
    My SLAM Another swamp, is it worth it? Drain or gain?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: 1st SLAM!
    Welcome to TFP! No need for a rough estimate, use PoolMath to calculate exactly much to add.
    Here are some intro Pool School articles to read while you wait for your test kit
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals
    Use PoolMath to figure out how much to add.
    Mar 2015
    Lebanon, PA
    79
    Re: 1st SLAM!
    Ok got home from work and check my FC3.5 and cc-1.0 figured out how much to add to bring back up to 16 for slam. Add that amount now 2-hrs later FC is .05 at best. This am when I left for work it was FC-8 and Cc 1.0 added the appropriate amount to bring up to 16ppm.
    Stenner 3GPD pump
    TF-100 Test Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: 1st SLAM!
    This is normal especially in the beginning. Just keep adding bleach to reach your targeted FC of 16. The more you can test the better.
    Lisa
    Mar 2015
    Lebanon, PA
    79
    Re: 1st SLAM!
    Complete set of readings are
    FC .05
    CC 1.5
    Alky 120
    PH 7.2
    Cya 38
    Temp 76
    Stenner 3GPD pump
    TF-100 Test Kit
    Mar 2015
    Lebanon, PA
    79
    Re: 1st SLAM!
    I guess I didn't realize I was going to be using $40+ per day of bleach.
    Stenner 3GPD pump
    TF-100 Test Kit
    Re: 1st SLAM!
    Can't you achieve the same thing by using non-chlorine shock to destroy the chloramines?
    18x37 IG 22,500 gallons...Vinyl Liner...Hayward EC-65 DE Filter...Hayward 1HP Super Pump...Aquarite SWG...TF-100 test kit.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: 1st SLAM!
    Quote Originally Posted by harpfamily View Post
    We prefer to to use bleach here.
    Quote Originally Posted by mkohr View Post
    The bleach use will slow as you progress. Add more bleach to get your FC back up there.
    Lisa
    Mar 2015
    Lebanon, PA
    79
    Re: 1st SLAM!
    So let me ask another question .... After I am finished withe the slam process how often would you need to slam again? Or is it just maintain your daily loss of chlorine?
    Stenner 3GPD pump
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    19,034
    Re: 1st SLAM!
    Quite possibly, never again. Certainly not during the swim season. Just maintain FC above the minimum for your CYA and it can;t get started. If you close your pool late and open it early when the water is too cold for algae, you might never see algae again.
    Mar 2015
    Lebanon, PA
    79
    Re: 1st SLAM!
    My family is starting to doubt me...especially since I opened the pool and with 10,000 of fresh water it was just cloudy. No swamp
    Or anything like that. As of now is is just a little cloudy. And I am still dumping Clorox in like I have stock in the company. I keep telling them to trust me.
    Stenner 3GPD pump
    TF-100 Test Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: 1st SLAM!
    Show them some of the SLAM threads and testimonials so they can see it works. The link to my SLAM is in my signature.
    Lisa
    Mar 2015
    Lebanon, PA
    79
    Re: 1st SLAM!
    I believe in it... They just keep busting on me and my new Clorox addiction
    Stenner 3GPD pump
    TF-100 Test Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: 1st SLAM!
    I am glad you believe in it and they will too when you show them how your pool looks in the end.
    Lisa
  20. Back To Top    #20
    DFW, TX
    24,497
    Re: 1st SLAM!
    LOL, get off the bleach! When your SLAM is complete you normally only need to add 2-4ppm per day to maintain FC level. The key to not having to SLAM your pool again is to never let your FC drop below the minimum for your CYA level here, Chlorine CYA Chart. Keep it at target or slightly above. Also, it is safe to swim as long as FC is below shock level.
