Thread: Return pipe pressure loss.
    May 2015
    Renton
    2
    Our 50 year old 85000 gal pool is under renovation for new plumbing, skimmers and equipment. 5 HP pump, 6" main drain line, 4" return. The other day he spliced the 3" dia east and west side of pool returns into one 3" dia line for approx 20' to go into the pump room and connect to the 4" dia manifold from the filter. A flow of 250gpm in 3" dia sch80 pipe is approx 12 fps, which is way more than the 5 -6 fps engineers usually target. So I looked on the drawing and saw, yes, in fact the engineer specified the 3" dia lines should connect to the 4" dia main indepentantly. They sould not be bushed down. Below is a picture.ReturnPlumbing2.jpg
    Inground 85000 gal dry gunite pool
    38,235
    Re: Return pipe pressure loss.
    Welcome to TFP!!!
    Is there a question here?
    If the pipe is not done to the drawing, then you should get the plumbers to fix it.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Yep. Plumber blew it. Tell him, not us. Don't let them fill in the trench until it's right.
