Thread: CYA 0? Several questions.
    Jun 2014
    Houston/Texas
    15
    I have the TF100 testkit, and have a pool just under 1 year old and have been using this kit and readings for most of that time. Aside from some calcium scaling on my spa spillway I think it's been going fine. I test all of the below once a week (and FC/PH every 2-3 days) and as of last weekend my readings were (Temp 80):
    FC: 2.5
    CC: 0
    PH: 7.8
    TA: 70
    CH: 300
    CYA: 30 (halfway between 30 and 20, since it had been clearly 30 for several weeks prior I marked it as 30 this time too)
    After I took this reading I added bleach (to get FC to 4) and muriatic acid (to get PH to 7.5), and added bleach/acid mid-week to try to maintain those numbers. I also had to fill some water on Friday as it was below my water line.
    Anyway on Saturday this weekend I measured and got the following (Temp 80):
    FC: 2.5
    CC: 0
    PH: 8.2
    TA: 70
    CH: 350
    CYA: 0 (I could literally see the dot with the tube completely filled up). The CYA being 0 I thought was a mistake but I tried the test again and got the same results.
    So I'm trying to figure out how my CYA could be zero, especially seeing as it's always been between 30-40 for the past year...the weekend before was the first time I saw it where it looked like it *may* be below 30, but it was between 20-30 at least. Now in one week it seems to be essentially ZERO without any major water change or rain. I hadn't seen any major changes in any of my other readings FC/PH and even my TA seemed normal, and CC was still 0.
    So I added some solid stabilizer in sock/skimmer to bring it up 20ppm and was going to check again this weekend, but decided to have TexSun do a test on my water and see what they showed my CYA at. Now they made me scared for something else. Here is what they recorded:
    Temp 76
    CYA 25 (they show it as a little low, but at least not zero - maybe my stabilizer had already started to take affect though?)
    Total Chlorine 2.9
    Free chlorine 2.8
    TA - ZERO! She told me DO NOT Swim in your pool right now and I need to raise this up.
    PH - 7.5 (she scratched through this though, because TA was 0 so said you couldn't trust that #)
    Borates 47 (I've never added borates! Was just investigating doing that but she's showing 47 already and I've never added???)
    So anyways - my questions
    1) should I trust ANY of what TexSun's reading says? Is it possible I'm doing my reading wrong (how could they have me ZERO TA when I have me comfortably at 70?) I realize they may not be totally accurate, but now I'm scared that mine may be way off, especially since I've seen scaling when I thought my PH was never abnormally high (occasionally gets high but I drive it down before it stays at that level). Also is it possible I do have borates in my pool or can their machine be that off? (side-note, I'm getting borate test strips this week as I was intending to use borates in next week or 2, so I guess I can answer the question on this one myself in a few days). Is there anything I can do to ensure my TA reading is correct and there's is wrong? I don't want the kids in the pool if it's dangerous for them?
    2) I'm assuming the answer for #1 may just be "trust your own tests over the pool companies", but even if that's so - how could have ZERO CYA all of a sudden? And what should I be worried about there (especially if my FC/CC/PH levels remain good?)
    3) I put the solid stabilizer in socks in my skimmer, let the pump run for the past 36 hours and have been squeezing them periodically (to get out the white dust). How long do I leave those socks in there? Will the solid eventually completely dissolve or do I dump it out of the socks at some point? Do I need to leave pump running until it's all dissolved?
    Some other points - pool water looks fine, not cloudy, not green...looks normal to me. I don't seem to be having to add way more bleach than normal or anything. PH doesn't seem to be swinging wildly, though it does raise every few days causing me to add acid.
    Thanks in advance for the help!
    20K gal, IG plaster/pebble-sheen, dual pump - Intelliflo VS and 2 HP Whisperflo pump, DE Filter 60 Sqft Plus, Pentair Kreepy Racer Cleaner, Rainbow 320 Chlorinator, spa, TF100, new pool (07/2014), Houston area
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: CYA 0? Several questions.
    Trust your test. Ph is on the higher end of the scale. I think they messed up on the TA test. Shoot for FC target level of 12 for 24 hours then let it drop to 4 since you think your CYA is about 30. Recheck CYA in a few days
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    38,537
    I am going to guess that the lighting conditions were different for your 2 CYA tests.
    1) I would ignore everything the pool store said ... for 1, with a pH of 7.5 a TA of 0 is IMPOSSIBLE!!!
    Trust you own test kit ... and I would forget the borates until you are comfortable with all the other maintenance.
    2) Like I said, likely testing error, different light, etc ... If you added 20ppm more, just retest it in a week. I would assume you are still around 30-40ppm.
    3) Leave it in the sock until it is empty ... should not take too long if you squeeze often.
