Results 1 to 8 of 8
Thread: AGP'S And Saltwater Chlorine Generators
    Fort Worth, Texas
    32
    One quick question, how fast will a pool with steel walls corrode using a Saltwater Chlorine Generator?? I assume that they are not recommended for above ground pools??
    28K IG, stonescapes pebble, raised spa, hayward heater, 2HP Super II pump, Hayward 60ft DE filter, built around 1980, remodeled 2007.
    ktdave's Avatar
    Katy, TX
    888
    Hakkamike,
    If you look at this thread, there is a discussion of a salt water chlorine generator called Chlorease that I think is specifically made for AG pools.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    I think SWG are fine with an above ground pool. The risk is that splash out will leave salt on the steel frame which will eventually cause corrosion. This will be a slow process, many years in most cases, and can be avoided by ocassionally hosing down the exposed steel with a garden hose. Several SWG are sold specifically for above ground pools.
    Ft Lauderdale, Florida
    1,455
    Here's MY two cents worth....
    A pool is a pool is a pool, regardless of if it's above ground or in ground; vinyl liner, fiberglass, or plaster; 1,000 gallons or 100,000 gallons. You still have water to treat.
    There IS no difference in the operation of an above ground salt system or in ground system. It's usually marketed to aboveground pools because they've taken alot of bells and whistles out of it. Basically, given you a simple system. The logic is that above ground pools don't normally cost as much or are as big as in ground pools. Therefore you're not likely to spend as much on a salt system.
    An abg pool, with 20,000 gallons will need to be treated just the same as an in ground 20,000 gallon pool. Period!
    There. I've said it.
    Back to watching the rain fall here in SUNNY SOUTH FLORIDA! Now who was doing that rain dance?????
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    NOT ME!!!!!!!!!!
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    Quote Originally Posted by Poolsean
    .......There. I've said it.
    The rain making us a bit testy, Sean??
    I think the OP was looking for info on the corrosiveness of the salt on the steel walls of his AGP...
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    1,455
    Yeah yeah....I know..it's those darn dancin Texans doing native rain dances... gggrrrrrr
    OK...I think Jason answered it well. Occasional rinsing of your pool walls will negate any corrosion issues. Rain fall, LIKE WHAT I'M GETTING TODAY, will also rinse down the salt.
    Now if I can just get my whip to reach far enough.....
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Ok, SORRY. Buggs told me to blow hard to get it to move away from here towards the South, but my aim was off to the SE......
    I agree on the salt issue. A good rinse and your good as new. The parts that are in constant contact are covered by a liner anyway.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
