Thread: Distinction (Steel) or Mission (Resin)
    May 2015
    Martinsburg, WV
    4
    Our local dealer sells Celebration Pools - Distinction and Mission. Mission has resin top rails and bottom wall channel, the Distinction is all steel, I believe. Pros/Cons? Thanks in advance.
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    Re: Distinction (Steel) or Mission (Resin)
    I don't know anything about that particular pool brand, but if you'll be using a SWG then resin is ideal to prevent rusting.
    ​Jennifer
    19k gal, 27' x 54" AG Aqua Leader Saltwater 8000 installed April 2014; Aqua Pro 19" Sand Filter System 1.5-hp Pump; Hayward Aqua Trol Salt Chlorine Generator System; Overlap Boulder Swirl Liner; Polaris 65 Turbo Turtle Automatic Cleaner; TF-100 Testing Kit
    Casey's Avatar
    SW PA
    10,461
    I've had steel and now I have resin n I'll go with a resin next time if my Sharkline Venture caput on me. I should be good with this pool for a very long time though.
