Results 1 to 16 of 16
Thread: abandoned pool and mosquitos
    So my neighbor more or less abandoned her house for several months and now her pool is a giant mosquito pond.
    Does anyone have any recommendations on what I might put in the pool to eliminate the mosquito's?
    We never had a mosquito issue prior to this event so it is most definitely associated with her pool gone bad.
    Donldson's Avatar
    NW Ohio
    2,926
    Re: abandoned pool and mosquitos
    I am not a lawyer, so the legality of what I say is up to you to determine and I take no responsibility.
    That said, if it is just being left to become a swamp then there are products that can be thrown in stagnant water to kill mosquito eggs and larvae. It may be worth contacting your city as well, some have mosquito control programs and will check it out for you.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I agree with Donaldson. I would contact the city or health dept. A mosquito breeding ground is not healthy.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Agreed, you shouldn't do anything on their property. Contact the owners and authority in charge.
    Essential Links:
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Contact the city/county authorities.
    In the meantime, you could toss a few of these over the fence, into the pool:
    Isolated Spa - 345 Gallons
    May 2015
    Wildorado Texas
    252
    I had this very situation and did as suggested, called the county extension agent. It took some time, but finally the property owner was forced to act. He wound up filling his abandoned pool with soil, then covering that with concrete. It was the site of a old, abandoned hotel. Skeeter problems all gone.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    +1 on tossing some Dunks in the pool and then call somebody.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    Plus one, and plus one of what JVTrain and Pooldv said.
    Divin Dave,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Where do you live?
    In LA County, an agency called "Vector Control" would be all over that green pool. Somebody - city, county, or state health dept - probably has something on their website if you try the search function on it.
    DFW, TX
    24,517
    What's our vector, Victor?
    Quote Originally Posted by pooldv View Post
    Thanks for all the reply's so far guys.
    Victor's vector is Northeast Georgia, it is very rural area.
    I have five acres of land and the neighbor in question resides on 2.5 acres.
    You would think that there would not be an issue given the amount of land however there is.
    I think I will end up giving her a call as the property is getting out of hand.
    The lawn is a foot high and the pool is a swamp. It is a shame because the property was always well maintained up until last fall.
    I she chooses to do nothing I will go ahead with the dunks and try to be patient as if I call the county she will know it was me and I do not need the headaches.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Essential Links:
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Call the homeowner first and if that does not work you will have one choice but to call the county. Sounds like she abandoned the property. Ask her if she can at least drain the pool if it is one that can safely be drained.
    Lisa
    Jun 2014
    Roseville, CA
    345
    We have one near where I live in Roseville, CA. The most the county will do is have vector control put in some mosquito fish.
    The guy who's house abuts to it, throws in chlorine pucks from time to time. The mosquito tabs might be a good idea too, if you can get the concentration up. Plus there is junk in the pool adding to the danger. Either way, given the thicket of regulations that control every iota of life in California, no one really gives a **** about diseased swimming pools.
    It's a rotten situation.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Unfortunately it is a vinyl liner in ground pool so I believe draining it will not be an option.
    She put a for sale by owner sign up last week however unless she mows the lawn and cleans the pool up no one in their right mind will ever look at it.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Nope she cannot drain with the vinyl liner. I would call her and suggest in order to sell the home she really needs to clean the pool and yard up.
    Lisa
