Thread: Pool water odor
    Pool water odor
    I have had my pool open for a couple weeks now, water is clear and balanced.
    What I am finding though is that I have a perfume type smell from my water. Because I live in canada I use RV Antifreeze in my water lines when closing my pool for the winter.
    I suspect that this is the smell I am getting from the water as some of the antifreeze makes it into the pool water when I open it. I do my best to blow the lines out so the antifreeze doesn't go into the pool.
    Any way I could possibly get rid of this odor from my water or will it just come out over time?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool water odor
    Time and Free Chlorine levels (properly maintained) will cure it I'm sure.
    Essential Links:
    Jul 2014
    Peoria, IL
    389
    Re: Pool water odor
    I get the same thing. I try to remove as much of the antifreeze as possible but can never get it all. If you have a cover leave it open as much as possible until the smell dissipates. That is what I have to do.
    At the beginning of the swimming year, right after I open, I will raise the FC level up above "normal" and that seems to take care of it.
    Not sure how you sanitize your pool but I have to use LC until my water gets warm enough for the SWG to work right. So I just dump in a little extra.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Pool water odor
    I didn't notice any smell to mine, and I blew 4+ gallons back in my pool when I turned the pump on. I wasn't in it immediately afterward though.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
