Thread: Pump Questions for 27' Sharkline Venture
    Nov 2014
    Alabama
    4
    Hey All!
    I'm about to pull the trigger on a 27' x 54" sharkline venture from PSW. I'm wondering if I should opt for one of their suggested pumps or should I elect to buy a different pump filter? I tried doing a search but the more I read the more I get confused hahaha. I'm looking for something that isn't going to be too much of a hassle but does a good job. My only experience with pumps/filters has been the cartridge pump/filter that came with the intex pool we used to have.
    My choices are:
    • Sand Filter & Pool Pump Combinations
      Carefree 19in Sand Filter Above Ground Pool System with 1HP Single Speed Pump
      Carefree 19 inch Sand Filter Above Ground Pool System with 1-1/2HP Single Speed Pump
      Carefree 22 inch Sand Filter Above Ground Pool System with 2HP Up-Rated Dual Speed Pump
    • Sand Filter & Pool Pump Combinations with Sand
      ClearWater 16in Sand Filter and Pump Above Ground Pool System
      ClearWater 19in Sand Filter Above Ground Pool with Hi-Flo Single Speed Pump
    Any help would me much appreciated!
    Thanks!!
    -Colin
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Pump Questions for 27' Sharkline Venture
    I would get the Carefree 22 inch Sand Filter Above Ground Pool System with 2HP Up-Rated Dual Speed Pump and run it on low. This will be much more energy efficient than the other options. And bigger filters are always better.
    Casey's Avatar
    SW PA
    10,457
    Quote Originally Posted by pooldv View Post
    Agree. The bigger the filter, the better and go with the 2 speed.
    Nov 2014
    Alabama
    4
    Great thanks!
    -Coiln
