Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Pentair CVA 24 Actuator Died
    Aug 2011
    Fort Worth, TX
    32
    Well, it appears the actuator for my spa control died last night. The switch on the back doesn't move it back and forth anymore. I did take the motor off the top of it and manually moved it so the spa would keep water at least. I will check to see if the connection came loose from either side prior to making a decision on what to do.
    My question here is should I replace it with the same thing? I would need a 180 valve controller, but is there a better option? This lasted about 3 1/2 years before coming to this apparent end. Wondering if another brand/model would be better for our setup since I have the opportunity to replace it. Any insight would be great y'all!!
    Thanks!!
    23x34' IG freeform play pool (18,850 gallon) ~ 7' spa raised 18" with 6 jets and 5 tier waterfall ~ IntelliChlor SCG ~ Pentair Intelligent VS-3050 variable speed pump ~ Clean and Clear 420 cartridge filter ~ Easy touch controller ~ Blue Granite Pebble Sheen ~ Intellibrite LEDs ~ Turbo twister slide ~ 8x8 flagstone tanning ledge with umbrella sleeve and bubbler ~ In-pool flagstone table with umbrella sleeve ~ 947 sq ft exposed aggregate decking
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    Re: Pentair CVA 24 Actuator Died
    My PB used all Pentair equipment except when it came to valves. He used Jandy valves and actuators and it he likes to use stuff that gives him little trouble in the long run. He services a lot of the pools that he builds. So i guess that would be a vote for Jandy by one PB.
    12K gal, custom flipped kidney bean with spillover spa. All Pentair equipment, Whisperflo 1 1/2 HP, 400K BTU heater, Intellichlor IC 40 SWG, CCP-320 Cartridge filters, Kreepy Krauly pool cleaner with bootster pump, QuartzScapes in Aruba Sky blue, LED lights and travertine tiles for decking and stones on rear edge for landscaping. TF-100 test kit w/ SpeedStir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Jandy is the most popular and we rarely hear about failures. Pretty much same for the Pentair also, just less people use them. Either is fine.
    Killer95Stang's Avatar
    Sunny SoCal
    592
    I would pop the cover on the motor and try to trigger the micro switches manually. Sometimes they go bad or slip out place causing the actuator to stop cycling. New micro switches for the pentair valves are sold on eBay for $11. In my case, new switches fixed the problem.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Dec 2014
    Riverside California
    482
    Quote Originally Posted by Killer95Stang View Post
    The actuators are pretty bullet proof, except for the micro switches. I have had a pair of actuators (Compool - now Pentair CVA-24) going on 22 years now and have had to replace the micro switches every 4 or 5 years. I also soldered all the connections inside the actuators, including the switches.
    Here is a link for the proper switches (Omron SS-5T)
    http://www.mouser.com/Search/Refine.aspx?Keyword=ss-5t
    One caution, do not attemp to bend the leads on the switches. I have found this to cause pre-mature failure of the switch. You can cut off the middle lead if you want.
    I always keep a batch of 4 of these on hand.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Jun 2015
    Houston, TX
    58
    Quote Originally Posted by gary300 View Post
    Thank you. This fixed my actuator. I ordered six of them and wish I had ordered a dozen.
    Sunny SoCal
    592
    Thanks for that link to Mouser Electronics, I just ordered a couple extra sets. This is a way better deal than the Ebay route I suggested.
    Jan 2016
    lumberton/tx
    1
    Thanks a lot for the link. I agree with the other person a lot better deal than ebay.
    I would also add that when repairing the valves make sure you apply some Vaseline around the oring on the shaft. If this oring tears or becomes damaged you will get water inside the actuator.
    Jul 2012
    Oklahoma City
    72
    I have been having a problem (twice) with the actuator not working on cold night (20F) but when it warms up, it starts working again. It is under 2 yrs. old. Do you all think it could be switch problem too?? Thanks!!
    IG gunite Edmond, OK(OKC), 18x36 freeform ~20K, 4-8' deep, Pentair equip, (2) 3hp VS+ pump, 520 cart filter, 3 LED, Easytouch8, ItellichlorIC40 SWG, Polaris 3900 cleaner, Spa 8'x18"raised, 20' raised bond beam 2 sheers, Stonescape Tahoe Blue quartz plaster, TF-100 kit.
    Feb. 25, 2014 dig started, May 24, 2014 filled.
    Dec 2014
    482
    Seems to me that the switches would be the most sensitive component about temperature. It would not cost you much to change out the switches and see. One other thing to try would be to unplug and re-plug the cable that goes into the actuator several times to break any corrosion that may exist on the contacts which may be temperature sensitive. Also make sure there is no water in the actuator which could freeze. I assume just one of your actuators is exhibiting the problem.
    Jul 2012
    Oklahoma City
    72
    Yes, it is just one actuator with the problem. Thanks for the suggestions, I will give them a try.
    May 2016
    Orange County, CA
    1
    Thanks for the advice on the switches. We have two Compool automatic actuator valves, and one recently stopped working intermittently, so we swapped the motor from one actuator to the other actuator and concluded that it is probably the micro switches that are causing the failure (there was still an intermittent problem after swapping the motors). Just ordered a dozen switches from Mouser and have some hope this will fix my actuator problem. This is the third actuator problem I've had in 3-1/2 years of owning a new pool. The first two were covered under warranty. This time I'm on my own and was dreading buying a whole new actuator set up. Thanks again!!!
    Gary, U Rock!! I was just about to buy a new valve when I stumbled across your post. Ordered the switches as per your post and it worked. Thanks for saving me $140!!
    Jan 2015
    Anthem, AZ
    188
    ive used 2 on an actuator this year. saved me a lot of time/money.
    19K IG Pebbletec with attached spa. 60sqft Cartridge filter, Intelliflow VS, 399k BTU Gas Heater, Pentair IC40. Phoenix, AZ, full sun.
    JoeGolan's Avatar
    Nov 2016
    Palm Coast, FL
    199
    I know this is an old thread but I had replaced the micro switches because of erratic operation but the actuator was still not performing right so i dug a little deeper and found a capacitor wired into the switches that had corroded leads causing the erratic operation. It was a 35 mfd, 100 V non-polarized.....
    found a 33 mfd flavor on line and reconnected it with gel filled splice connectors and all is back to normal for $2 in parts.
    Jun 2017
    Houston/TX
    2
    My actuator has been intermittent. Changed the micro switches but still intermittent, just in one direction. Took a close look at the 3 position switch at the bottom and saw one of the wire socket plugs loose. Still hanging on but loose. Tightened all the sockets and no more problem. May never have needed to replace the micro switches.
    Jul 2016
    Valley Springs, CA
    3
    My actuator has also been intermittent for a month or so. Ordered the Mouser micro-switches, replaced both in the problem actuator and it works great! All for a couple of bucks.
    May 2013
    Toronto, Canada
    73
    My Compool CVA 24 actuator has also .stopped working. The motor seems to be gone. Can I just remove the actuator and replace it with the Jandy model? Will the temperature sensors still work? What about the Hayward model of a similar product? Am a bit confused as to what is compatible with what. There are many parts
    1- control panel
    2- actuator
    3- 3-way valve
    4- temperature sensor which decides where the water goes (pool or solar panels)
    All 4 pieces have to work together. So the actuator has to be able to plug into the control panel for power. The temperature sensor has to be connected to the panel and the panel has to be able to activate the actuator.
    Am kind of at a loss here. There's Hayward, Pentair/Compool, Jandy. Are all pieces interchangeable and easily replaced by a true novice?
    Philip
    12.5x21.5x52" on-ground 29" below ground (6000 gallons water), .85 HP Hayward SP26115VSP , Hayward XStream 100 sq.ft. cartridge filter, Hayward AquaRite salt system, 160 sqft of Aquatherm solar panels on 12' high flat roof 25' away from pump, Goldline auto controller for solar, Heat Pump, May->October @77+ in Toronto, Pool Python.
    Sunny SoCal
    592
    Most brands are just a rebranded compool cv-24. Intermatic also makes a cheaper version which is compatible. All you have to do is replace the actuator on the three way valve body and then plug it into your solar controller. Then make sure the toggle switch on the bottom is in the correct position.
  20. Back To Top    #20
    May 2013
    Toronto, Canada
    73
    Thanks. So had a new Pentair cv-24T actuator installed to replace the older one. It works but now the Compool lx220 panel does not work on AUTO. It will turn the actuator by moving the switch to ON (and the solar light then comes on) but the moment I switch it to Auto it turns the solar off. The toggle switch is in the correct position. I suppose the sensors may have failed or the sensor wire got disconnected from the panel when they replaced the actuator ( done by a pool company not that familiar with solar) or perhaps the lx220 panel is gone. Hayward makes a replacement product. Can get the panel and sensors or for small extra amount panel, sensors, 3-way valve and valve actuator. All covered by a warranty of 3-5 years. Wondering how long these valve actuators last and whether it's worth have a spare. My lx220 panel is over 12 years old and no support around here unfortunately. Is there a quick way of checking the panel?
    Philip
