Results 1 to 8 of 8
Thread: Am I doing this right?
    mrswilson's Avatar
    Mar 2015
    Redding, CA
    41
    Hello,
    I successfully cleared my swampy pool thanks to TFP method and some wise folks on this forum. So thankful!
    Now I am maintaining it using only bleach but I seem to be burning through the bleach a lot quicker than I anticipated. My cya is 40. So I have been bumping up my chlorine to 8 every night, my FC is usually between 4 and 4.5 before I add any bleach at night. So according to pool math I should add 181 oz or 1.9 jugs of bleach. Each bottle is $2.93 at Walmart so everyday I use $5.52 in bleach. Is that seems right? It's not even super hot here and I am kinda concern at how much this pool is going to cost me monthly to run.....
    Sara- 29,000 gal IG Plaster '93
    DE system:3 (S8D110) 58 sq ft
    Pentair Superflo 3/4 hp single speed
    Booster Pump 3/4 hp-Polaris 280 vac-sweep
    8 return jets- 2 skimmers- TF-100
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Am I doing this right?
    You might want to do an overnight chlorine loss test to make sure there is nothing trying to grow in your pool.
    http://www.troublefreepool.com/conte...loss-test-oclt
    mrswilson's Avatar
    Mar 2015
    Redding, CA
    41
    Ok I'll try that. I'll test it right now.
    FC: 12
    CC: .5
    Thanks
    I actually just realized my jugs are 121 oz not 96 oz so that changes things a little....my pool calculator on my phone defaulted to 96oz and I didn't notice. So that's why I am at 12 instead of my target of 8.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Let us know what the overnight loss was. If the loss was ok, you can also move your Cya up to 50 and see if you get less FC loss during the day.
    Essential Links:
    mrswilson's Avatar
    Mar 2015
    Redding, CA
    41
    FC: 9.5 this morning. Dang my pool water is super clear and sure doesn't look like it has algae.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Keep at it you will Pass the OLCT before you know it. Glad you figured out the bleach ratio better. You are getting close. Keep brushing the pool too, walls fixtures ladders floor
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes something is still in there getting your FC. Keep SLAM levels until you can pass all criteria as AZgirl mentions above. Don't increase the Cya level yet.
    Essential Links:
    mrswilson's Avatar
    Mar 2015
    Redding, CA
    41
    Ok I will start slambing today. Thanks for your help.
