Thread: Can I convert a stenner 45mp2 to a 45mphp10
    Dec 2014
    Linda, Ca
    13
    I have a chance of getting a good used low pressure 10 gpd 45mp2 for a free through a work friend. The pump tube needs to be replaced and its missing the injection point. Through my research and searches here, can I get the the high pressure pump tubes and a check valve and it be a high pressure set up? Online and in the manuals the pumps and heads and rollers are the same parts just different tubes and injection/check valve?
    Is it possible that i can get a high pressure setup for just the cost of the pump tubes and the check valve. Or should I just stick with the low pressue items since i know that it will definately work. I really would like to get a chlorine injection system going.
    Thanks
    14500 gallon, 24' round vinyl agp buried, pentair tagelus 60 sand filter, max-flo vs sp2302vsp, TF-100 testkit
    22,553
    Re: Can I convert a stenner 45mp2 to a 45mphp10
    It's certainly possible to convert the 45MP2 to a 45MPHP10. All it requires is a #2 tube and an injection fitting. There are two differences between the high pressure and low pressure models. 1) The injection fitting and 2) not all the pump tubes are rated for use in pressures up to 100 PSIG. They will fit the pumps, but just aren't rated as high as the rest.
