Thread: Used flex pipe when building inground pool
    Not knowing about termites and flex pipe before we had our inground vinyl pool put in the question is... Anything I can do now or just sit back and wait? The concrete / brick border patio is going in this coming Spring. I live on Long Island
    We did take down a 12 year old above ground pool with no liner damage if that is a plus. And what is the percent of pools going in that use this flex pipe and is the cost difference that great?
    Aug 2007
    Powhatan VA
    Re: Used flex pipe when building inground pool
    Hi Tom -
    I'm in central VA and I used flex pipe on my inground pool. I was not aware of a termite problem until I read your post. Termites are not a big issue here but I will be paying attention now.
    The pool company I bought the kit from uses flex pipe for just about all their installs. It is run inside a length of drain tile in case it needs to be replaced. Hopefully yours was done the same way. It was a little more expensive for materials, but it was much easier for a diy person to install.
    20x40 IG Vinyl
    33k Gallons
    Triton TR-100 Sand Filter
    Pentair WFDS-6
