Thread: Pentair ic40 having issues
    Having the same issue. My IC40 indicates salt level is 4750 but tests indicate it's more like 3000. The salt level light is flashing green - all other lights green. All I want to know is if my cell will continue to produce CL even if it thinks the salt level is high? Thanks for any help.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: Pentair ic40 having issues
    Yes, the pentair IC are one of the few (only?) swg that continue to produce chlorine with high salt condition. I put over 5000 ppm in my pool and it produced CL for two years without adding salt, finally had to add salt this spring. Yes, i am a genius sometimes.
    Jun 2014
    Roseville, CA
    343
    You can do a chlorine test at the water return inlet in the pool. The test for chlorine should be deep yellow if you are using a basic tester.
    I don't think you will hurt anything, but the spec's are there for a reason. Maybe.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    DFW, TX
    24,468
    LOL, yes maybe indeed. Pentair does recommend partial draining to keep salt below 4500 to avoid damaging equipment.
