Results 1 to 8 of 8
Thread: DE Filter Pressure Gauge needing to be replaced
    Dear all,
    I noticed the pressure gauge for my D.E. filter starting to leak air lately and want to replace it. However, after several trips to the local pool stores and hours of searching the viable option online, I have yet to find the suitable replacement part. I am hoping the experts on this forum can help me to identify the right type of pressure gauge (& assembly/air relief valve) for my D.E. filter. Any suggestion/advise are welcomed and very much appreciated.
    My filter is Pac Fab Nautilus Stainless Steel 48sf D.E. Filter, but I am not sure about the manufactured date or model #. However, I know the filter was installed before 1995. I have also attached the picture of the pressure gauge below. Thanks again for your advice in advance.
    4knights's Avatar
    NE Kansas
    419
    Re: DE Filter Pressure Gauge needing to be replaced
    WELCOME!
    Edit your signature to show what equipment and pool you have.
    I didn't see a picture attached but here is a nice spot to get your test kit and gauge
    http://tftestkits.net/Flow-Meters-and-PSI-Gauges-c12/
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Thanks so much for the quick replay, but it does not seem to have the air relief valve that will fit my filter.
    My image is saved here:
    https://www.flickr.com/gp/132353406@N02/26eW7K
    4knights's Avatar
    NE Kansas
    419
    Still can't see the picture but is this what your looking for?
    http://www.inyopools.com/pool_parts_...less_d_e_.aspx
    4knights's Avatar
    NE Kansas
    419
    Now I can see it, it looks like a standard air bleed assembly like on my pentair sand filter.
    It has a brass double side threaded screw that goes into the top of the filter then the plastic piece had the built in air bleed plastic screw and you add the pressure gauge
    http://www.sunplay.com/pentair-air-b...bcXBoCySnw_wcB
    Thanks! Exactly what I was looking for.
    4knights's Avatar
    NE Kansas
    419
    You're welcome, Glad I could help. You should be able to walk into any pool store and pick that up.
