Thread: running the pump
    May 2015
    Eastern Ontario
    3
    running the pump
    Hi there,
    Newbie here with an older gunnite pool. I'm wondering if I need to run the pump day and night or if I can get away with something less. Do I need a check valve in line to shut the pump off for extended times or should it prime itself again?
    3/4 hp pump, sand filter.
    Captain Canada
    Captain Canada
    In ground gunnite pool
    size TBD, possibly 147,000 litres, a little under 20X40
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Re: running the pump
    Hi Captain,
    Welcome to TFP.
    To answer your quetion, NO, you dont have to run the pump day and night. You only need to run it enough to skim the water. If you have a saltwater generator, then you'll also have to factor in how long you need to run it to make enough chlorine.
    In ground pool pumps are self priming. They should not need a check valve.
    here is a handy write up about pump run times.
    http://www.troublefreepool.com/conte...-pump-run-time
    Quote Originally Posted by captain canada View Post
    Hi there,
    Captain Canada
    Divin Dave,
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Welcome to TFP!
    Support the site
