Thread: motor got wet??
    May 2015
    perryville/Kentucky
    2
    motor got wet??
    Hello all! I hope you can help me save my pump. Last night I started my pool and realized the hose leading into my motor was not tightened. Stupid me wiggled it before tightening it, I seriously don't know why, and guess what....my motor got wet, then hot, then stopped. If I let it cool off it will start again for several seconds before it gets hot again and shuts off (throws the little switch at the outlet). When I first had my little accident it also smoked and now it doesn't. Is that a sign it is drying out? Have I killed it?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: motor got wet??
    The magic smoke escaping is usually a sign of a dead motor, I would suggest letting it sit and dry for at least 12 hours and then try again.
    Ike
    May 2015
    perryville/Kentucky
    2
    Re: motor got wet??
    Thanks! I will, it didn't smoke the last time I tried it but still cut off.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: motor got wet??
    A day baking in the sunlight may help too if your pad is exposed to direct sun
