Results 1 to 14 of 14
Thread: Something is using up my FC or my salt cell isn't working properly.
    May 2012
    Oconee, Georgia
    82
    FC= 7
    CC=0
    PH = 7.2
    ALK = 70
    CH = 270
    CYA = 70
    Salt level is 3600
    Borate level is 50
    I have done over night tests and I pass everytime. The problem is I am running my IC40 at 100% for 8hrs a day and it is just maintaining 4. I got it up to 7 by adding bleach today. I do have pecan trees in my yard that are dropping those green tags in my pool Could pollen be eating up my FC? The pool temperature is 83.
    18'x36' inground vinyl liner.Pentair Sand Filter SD-60, Pentair EastTouch IC40 Salt Gen.
    Pentair Legend Cleaner. Pentair SuperFlo 1 hp pump. Color LED pool light.
    Taylor K-2006 (FAS-DPD) w/ SpeedStir. Pool Built October 2013.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Something is using up my FC or my salt cell isn't working properly.
    What does your water look like?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2012
    Oconee, Georgia
    82
    Water is beautiful couldn't be any better
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    What is your FC?
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Yes pollen consumes FC. It's organic.
    May 2012
    Oconee, Georgia
    82
    CC was zero
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    If your CC 7 then I think you need to SLAM. Your Ph is perfect for a SLAM. Your CYA is high if you are not on any water restrictions you can do partial drains and refills until your CYA drops to 30/40. At 70 you are going to go through a lot of bleach.
    Shock level for CYA of 70 is 28. I also agree pollen and the sun are contributing to FC loss. Don't worry about your SWG right now.
    Lisa
    May 2012
    Oconee, Georgia
    82
    Quote Originally Posted by Azgirl71 View Post
    What I meant was my CC is zero
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Ok.when you said they were the same it was not looking good. Well you said your water is clear, no overnight loss and cc is 0 which leads me to believe the issue besides sun and pollen is your SWG.
    Have you cleaned the cell.
    Lisa
    May 2012
    Oconee, Georgia
    82
    I cleaned it a couple of weeks ago wasn't bad though.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I am at a loss. Can only run my SWG at 100% and I run it for 5 hours. My FC is high still from coming off my SLAM and I actually stay about the same or within .5 on my evening tests. I am only running it to help with aeration as I added MA to bring my TA down so I can bring the PH back up. The only thing you might try is test FC in the morning turn SWG on about 10 am and let it run u til about 5pm and test FC again. If you only lost or gained 1 pm then it is probably working. If you lose a lot then I would guess your cell may be bad.
    Lisa
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    I would probably add bleach daily for a little while and monitor the FC consumption to see what is going on.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    if you get a sample bottle and hold it over return jet with swg running, close bottle then remove from pool
    test this water for fc, should be substantially higher
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    May 2012
    Oconee, Georgia
    82
    I am leaning towards all of the pollen from pecan trees. If it will ever rain it would help some
