Thread: Why do I forget every single year?
    Jun 2010
    Dayton, Ohio
    241
    I have the Taylor K-2006 test kit and every year I forget how to use it. I am testing my FC but the instructions say nothing about diluting the pool water. However I know I dilute it with tap water every time just can't remember why or what the ratio is or what to do with it. So sorry I know I sound like a moron.
    AGP: 24' x 52" cartridge filter: 13,500 gallons. Taylor K-2006 test kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Why do I forget every single year?
    You only need to dilute stuff if your CYA is above 90.
    Extended Test Kit Directions goes into great detail for bizarre situations. Otherwise, watch the videos to refresh your memory. Ignore the TF100 - your K-2006 uses the same tests.
    Jun 2010
    Dayton, Ohio
    241
    Wow. Well that's not the case at all. So just follow instructions they way they are and I'm fine. Thanks for not calling me out on my stupidity. Video was perfect thank you so much.
