Results 1 to 9 of 9
Thread: Hello from Victorville CA.
    n9udt's Avatar
    May 2015
    Victorville
    8
    Just wanted to say hello people. Im learning alot here and im getting ready for the 2015 Season! Thanks to all of you that contribute and Happy Mothers Day to all the Mothers out there!
    Intex Easy Set Round 15' x 36" 2,800 Gallons above-ground vinyl pool, Intex Krystal Clear Sand Filter Model FS70110 with GFCI, and a pump flow rate of 2,800 gallons per hour. Clorox Pool&Spa 25-lb Sand Pool Plus. Shock = 8oz hth Ultra once a week. Sanitizer= hth Ultra 3" Chlorinating Tablets in Floating Chlorine Dispenser. Manual vacuuming using Weighted Triangle Swimming Pool Vacuum Cleaner Head Attachment.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Hello fro Victorville CA.
    Hi, welcome to TFP!
    Love TFP? Become a
    TFP Supporter!
    30,415
    Welcome to the forum.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: Hello from Victorville CA.
    Welcome!
    You can become our expert on windblown dust, since you're from Victorville.
    A word of advice: unless you just filled your pool, your Calcium levels will be outside the recommended levels. Just accept it. It is possible to keep things balanced with CH up to about 800 without too much effort. Above 1000 CH, it's next to impossible.
    If you have any lawn, use pool water to irrigate and refill the pool with fresh. That keeps the CH down. You'll lose some stabilizer, too, but that will buy you some elbow room to use pucks if you leave town for a few days. And if what I wrote after the dust makes no sense, don;t worry. It will soon enough.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Howdy!
    Divin Dave,
    n9udt's Avatar
    May 2015
    Victorville
    8
    Thanks Dave! You have a great Site here!
    n9udt's Avatar
    May 2015
    Victorville
    8
    Yep! i'm with you there. I did add about 600 gallons of fresh this season already. I should be ready for that 110 deg heat when it hits up in the high desert. Hay, is your heater Gas or elect? Talk with you again.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Casey's Avatar
    SW PA
    10,432
    Welcome to TFP.
