Thread: Observations on my AquaCal heat pump
    Aug 2014
    Seminole, FL
    92
    I haven't used it in the 10 months since buying the house, so I thought it was time to put it through it paces. Here's the results before my observations.
    Model: SQ110R (I think ... model no on plate starts 110)
    Btus: 91,000
    Weather: 100% sun all day, little wind, forecast high of 90
    Start time: 7:45am
    Pool temp: 80
    Air temp: 75
    Heater temp:78
    Return jet temp: didn't take
    Electric meter: 39694
    % sun on pool: 0
    Time: 11:45am
    Pool temp: 83
    Air temp: 82
    Heater temp: 80
    Return jet temp: 88
    Electric meter: 39723
    % sun on pool: 80%
    Time: 1:45pm
    Pool temp: 86
    Time: 3:45pm
    Pool temp: 88
    Air temp: 87
    Heater temp: 89
    Return jet temp: 92
    Electric meter: 39751
    % sun on pool: 80%
    Electric consumption was daily normal otherwise.
    The air temp was taken near the heater. This location is probably the coolest on the property .. full shade all day.
    We don't get full sun on the pool until just after noon, and only for about 3 hours due to location and trees. The pool is also screened. Full sun temp at 4pm was 95.
    We used 57 kw total from start to finish including normal useage. At our most expensive rate (> 1000kw per billing cycle) of approx 13.7 cents per Kw before taxes and fees, that cost less than $8 to heat the pool to a level I could get waterlogged at! Actually 86 was good enough for this English blood that's used to swimming in much cooler temps. If my maths correct, I'm impressed, and will definitely be turning it on again.
    I am wondering if I should have waited until the air temp was higher, so the heat pump worked more efficiently. That's the next test.
    Mike
    (Better change my sig)
    Built 1980, 19' x 30' almost rectangular, screened 15,000 gal, plaster, Hayward DE 3620 filter (currently using cellulose), Emerson 1081 1HP pump, AquaCal Heatwave SuperQuiet SQ110R heater, Zodiac T5 Cleaner, Taylor K-2006 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,493
    Re: Observations on my AquaCal heat pump
    Good info, thanks for sharing. I think heat pumps are pretty efficient above 70.
    Apr 2015
    Glenwood, MD
    12
    When you say "57 kw total from start to finish including normal useage", does that account for everything running on your property or just the heat pump? Obviously, your pumps are running the entire time and on a day like that I assume your air conditioning was running constantly as well. Not to mention all of the other stuff in your house. Have you taken a baseline of your daily consumption on a similar day and subtracted that amount? Or perhaps I am not interpreting your post correctly...
    45 x 20 (31k gallon) free form, 2 HP Pentair WhiperFlo, 3/4 HP waterfall pump, Black Pearl Pebble Tec, Aqualcal SQ175 Heap Pump, Raypack RP405 Propane Heater
    Aug 2014
    Seminole, FL
    92
    No air all day, just one washing machine and dryer cycle, and music center blasting! All normal. I run the pump for 4 hours a day normally. $8 is the max, probably more like $5.
    Apr 2015
    Glenwood, MD
    12
    It was 95 degrees and you didn't run your ac? You are a better man than me, sir!
