Thread: Pump crapped out
    Pump crapped out
    Intex pump has seen it's last day. Thinking about purchasing a blue line pump and still use intex sand filter. Should I go with the 1 HP or would the 3/4hp be sufficient?
    Clarenc
    Intex 22x52, 10500 gals. Intex sand filter system with .95hp motor. Separate intex swg.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pump crapped out
    I would think the 3/4 would do it on that setup, but don't go above what the old one was. It may be too much for the SF and push things through it.
    Welcome to TFP!
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Consider a 2speed pump that you can run on low most of the time for more energy efficiency while filtering and high for vacuuming.
