Results 1 to 8 of 8
Thread: My pool is falling down
    May 2013
    Louisiana
    12
    I have installed a 18 x 33 AGP on one end the support pipes have flattened out and the wall is buckling. Is this fixable? The pool was about 18 inches from being full when this was discovered. I have not cut the skimmer or return jets out yet. I'll get som pics very soon
    24' 52" intex-----gone
    18x33x54 ABG 7 ft deep end buried 2 ft in the back breaking hard red clay
    Hayward 20 in sand filter 1.5 hp power flo pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: My pool is falling down
    We talking about level, flat, solid ground here?
    May 2013
    Louisiana
    12
    Very level had to back fill a bit but not in the area that is problematic
    Apr 2010
    East Texas
    9,581
    Looks like that problem area compacted or "sank" as it got some water pressure on it to me.
    May 2013
    Louisiana
    12
    I'm draining it now to investigate further. I hope I can fix it Nd it's not completely ruined.
    Casey's Avatar
    SW PA
    10,427
    When a pool buckles and bulges like that, it can only mean one thing, that area is too high, meaning your ground is not level.
    You put the top rails on so it's got that wall essentially locked in place. As you add the water, the frame isn't moving but the walls start to bulge,buckle and pop out of the tracks.
    I'm sorry but... You need to drain the pool immediately and relevel the site.
    May 2013
    Louisiana
    12
    While draining the pool we used a transit and checked for level at every support post. It was within a quarter of an inch all the way around. The pool is on Louisiana red clay it is so hard that a bobcat couldn't break ground. We did find that the measurements were off not sure how this happened. Instead of 33 ft 2 inches we had 32 ft 10 inches several other places were of by an inch or so. What I am thinking is that as the pool filled the pool walls moved and the legs didn't and that caused the collapse. Does this sound feasible? I have everything back in place and filling it back up again. Keep your fingers crossed for me.
    Casey's Avatar
    SW PA
    10,427
    Good luck! If that was my problem, I'd be saying some very colorful words! lol
