Results 1 to 9 of 9
Thread: Hubby added cal hypo now water is cloudy
    Aug 2014
    atlantta
    24
    I was away and DH thought he would help by adding cal hypo to shock the pool. I've returned and the water is milky blue- I think he added some clarifier- but he wont admit it
    So heres my readings"
    PH: 7.2
    TA:100
    CH: 10--
    Cal: 180- I know this is low but I am adding a little calcium at a time.
    Will the milky go away? Should I let it go away before I start the shock process again... using bleach this time!
    38900 gallons ,IG ,Gunite, sand filter ( swim quip from the 60's), pump: Hayward SP2610X15 1.5 HP single speed, pool installed?? late 60's, re- surfaced October 2012
    38,275
    Re: Hubby added cal hypo now water is cloudy
    What does a CH of 10-- mean? Is that suppose to be FC since I am guessing that Cal is supposed to be calcium (CH)?
    What is your CYA?
    What test kit are you using?
    Aug 2014
    atlantta
    24
    What is your CYA?
    Sorry--- yes I meant FC of 10 and the CH is 180.
    The CYA is 50- My pool is in full sun all day no trees. I thought I read that was a good number?
    Im using the Lesley pool kit you all recommend for the PH, TA, CH, and CYA. I use a more specific test kit for the FC- I believe its a more specific chlorine test- tests high chlorine levels for shocking-again on that I saw recommended on here.
    38,275
    Ok sounds like you are in good shape as far as the test kit. If the cloudiness is just from the cal-hypo it should clear up. Usually that only happens at higher pH I thought.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by babsh View Post
    Why are you shocking your pool? Do you have algae and are in a SLAM?
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    You are not alone. Cal hypo cloudiness is a common topic here.
    Fingers crossed it's not some reaction between undissolved particles of Cal-hypo and clarifier. About all you can do is open a can of POP. Pool Owner Patience.
    Aug 2014
    atlantta
    24
    Yes, I was in the middle of slamming pool..we had the start of algae issues..... had to leave for a day... bad timing... thats when hubby took over and used the cal hypo instead of bleach as I instructed.
    hence my question... should I just let the milky go away first, before I start the slamming process again. I think I still have an algae issue... my FC is getting eaten up. I don't think I should wait... I'm basically "running on instruments" when I slam the pool. Just taking readings- not really basing on clarity... that make sense?
    May 2014
    Franklin, NC
    9,184
    SLAM away.
    Support the site
    Richard320's Avatar
    Jan 2010
    18,988
    Kill the algae. The cloudy should dissipate. Be patient with the cloudiness, be aggressive with the algae.
