Thread: SWG cycles on and off
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Does any know if an SWG cell cycles on and off based on the chlorine level? Right now, I keep mine at 36%. At that level the amps and instantaneous salt level are 0. If I boost it up to 40%, it starts to generate. Putting back to 36% shuts it back down again. All lights are normal no mater what it is doing.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    38,299
    Re: SWG cycles on and off
    The % is the amount of time the SWG actively generates in some time period (usually around 2 hours).
    If we assume 2 hours cycle, at 36% it would generate for 43 minutes and then sit idle for 77 minutes.
    It is not based on FC level at all.
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    I did not think of that. But, it makes sense. It does not talk about that in the manual.
    Steve
