Results 1 to 11 of 11
Thread: Return Line Size for AGP
    Sep 2011
    Omaha, NE
    95
    I had read the threads on line sizing and head loss pressure and I just can not seem to wrap my head around it and loose myself in the material.
    Here is my thought, right now I have 1.5" suction and return PVC piping. When my pump is on high speed, I get a very fine slit in bottom of pool, when in low speed, no silt. If I increase the return side piping to 2", will this reduce the pressure coming from the filter that is pushing the fine silt through? Also, if I remove my "eye" on the return in the pool, I do not get the silt. I want to be able to have the return eye in while on high speed without the silt!!
    16X24 Oval Doughboy
    10,000 Gallons~
    Pentair Dynamo .75/1.0 HP pump
    16" Pooline D-400 Sand Filter w/ 6-way valve
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Return Line Size for AGP
    Have you tried using a little DE in that sand filter first?
    Sep 2011
    Omaha, NE
    95
    Yes, did not work
    16X24 Oval Doughboy
    10,000 Gallons~
    Apr 2010
    East Texas
    9,621
    What size is your sand filter?
    Sep 2011
    Omaha, NE
    95
    I am not sure, the stickers have come off, here is a link to the picture of picture of it. For some reason, not letting me upload a picture right now. It is from a Doughboy
    http://www.troublefreepool.com/threa...for-a-new-pump
    16X24 Oval Doughboy
    10,000 Gallons~
    30,421
    Your filter and your pump appear to be about the right size. Typically, you will never see ANY debris from a system that is properly matched. I would suspect the laterals inside you filter may have a hole in them that is allowing debris through.
    I am still thinking about the eyeball dilemma and can't understand if that should have an effect but apparently it does.
    Apr 2010
    East Texas
    9,621
    No eyeball in let's the water run at full bore (less restriction) and is bound to reduce any back pressure on that line? When I run on low speed, in order to create more "flow"-----I screw in a reduced sized eyeball.
    How far is your pipe run from the filter back to the pool?
    Sep 2011
    Omaha, NE
    95
    I am not at home right now, will have to measure it, but it around a 6' to 7'. That was my question in the original post, if putting in the 2" PVC would reduce the pressure at the eye?, so I can run full speed when vacuuming, etc....
    16X24 Oval Doughboy
    10,000 Gallons~
    30,421
    .Not appreciably. The "pressure" or resistance on the pressure side of the system is produced mostly by the filter. All components of the pressure side provide some resistance but changing from 2" to 1.5" will have negligible effect.
    If you remove the eye, your pressure drops. With less total pressure, I suppose it might affect the leak of silt.
    That said, that silt leaking indicates damage (probably in the laterals) and, if that is fixed, your silt should disappear.
    What is your current psi?
    Sep 2011
    Omaha, NE
    95
    Will have to look at PSI's when I get home, just can not remember. I kinda had a feeling it was the laterals, just trying to hang onto every dollar until I have to....
    16X24 Oval Doughboy
    10,000 Gallons~
    Sep 2011
    Omaha, NE
    95
    My pressure reading are"
    High speed: 16psi
    Low speed: 8psi
    16X24 Oval Doughboy
    10,000 Gallons~
