Thread: First opening -success
    Jul 2014
    Hudson Ohio
    142
    Opened the pool for the first time yesterday. I take it as a win! Took the cover off carefully and found crystal clear water inside. Added about 2k gallons of water. Then 1# of shock. Just need to run the vac to get the leaves.
    FC - 14.5 (shocked it)
    TA - 230 (battled this last season as well)
    CH - 200 (vinyl)
    CC - 0
    PH - 7.5
    24'x54" AGP 13,500g AquaLeader Sentinelle | Hayward Voyager CC150 sqft cartridge filter | Hayward 2hp 2spd pump | Hayward Aquaray Cleaner
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: First opening -success
    Nice. Glad you had a easy open.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Oh hey that's great!!
    Welcome back!
    Essential Links:
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Wow the TA is really high. Is your fill water super high too?
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jul 2014
    Hudson Ohio
    142
    Quote Originally Posted by Defgufman View Post
    Yeah it is pretty high. Works great for my salt water reef aquarium. But the TA was high last year as well. I am going to try an lower the pH and aerate to lower the TA.
