Results 1 to 7 of 7
Thread: Re-plumbing of supply lines
    Apr 2012
    Morgan Hill, CA
    16
    Ok, first plumbing project complete, thanks again to everyone for their help. That project is located here: http://www.troublefreepool.com/threa...How-much-to-do
    There is a second area of my pool plumbing that is giving me problems - the area is more complicated than the first project. I have included a hand sketch below along with a photo. Its the plumbing area on the supply side on the way back to the pool and hot tub. Key history note - a few years back my primary pump seized and I had it replaced. The old pump was 2.5hp, the replacement pump is 2hp. Long story short the original plumbing was tuned to the 2.5hp pump - the flow hasnt been quite right since Ive been running the 2hp pump. Here are the key problems I'm having:
    1. When the primary pump switches off the water drains from the hot tub back into the pool. The right angle check valve on the main line is an old Ortega model and Ive replaced the internal part multiple times. The smaller check valve on the 1" line I assume is no longer working as well. So I need to replace the check valves.
    2. With the 3 way diverter valve closed to the hot tub and the solar is off I get a good waterfall coming out of the hot tub while the pump is running (the system is using the 1 inch line to still get water through). If the solar turns on the waterfall from the hot tub to the pool slows to a dribble. This used to work with the old 2.5hp pump but no longer works with the 2hp.
    3. Not a problem per se but I want to eventually install a control system on the pool so its not all manual. I dont want to do anything here that makes that hard to do later.
    So, I'm assuming I need to replumb this entire area. In the sketch below I have noted with the red arrows where I think I need to cut. I'm looking for validation of my plan:
    1. Cut out the plumbing per the diagram below
    2. Replace old 90 degree Ortega check valve with a new Jandy straight line one that will be a few inches lower in the system. (all of this is below the current hot tub water line by at least two feet)
    3. Insert isolation valves on both supply lines to the pool and hot tub to help compensate for my weaker pump. I assume I need these to adjust the waterfall flow - when I move to a control system the current solution of a jandy valve turned part way wont be possible.
    Questions about my plan:
    1. I assume moving to a straight check valve and removing the old 90 degree one is ok, correct?
    2. Is there a better way to plumb the 1 inch pvc that keeps some water always running to the hot tub?
    3. I cant figure out how to cut after the inline chlorinator - I have to cut above it in the line. I can either replace it with a new one or should I consider inserting a salt system at this point?
    4. Any issues with my idea to insert isolation valves?
    Thanks everyone. Looking forward to good discussion on this.
    Mark
    16,000 gallon AG pool,plaster,raised hot tub/waterfall,Hayward DE6020 filter,pump1/Waterway 2hp,Intermatic dial switch,pump2/Waterway 1hp for waterfalls,Polaris 360,Rainbow 320 chlorinator,Teledyne ESC furnace,Compool LX-220 solar,Currently under water restrictions - no filling pool beyond 12 inches at a time
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Re-plumbing of supply lines
    Sorry no one has replied yet. I don't know plumbing but want to bump your post for you.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Hi, I am going to reply in red within the body or your post. I also want to say, that .5 hp drop should not have made that a huge difference in the pump's performance. Can you post a picture of the pump's label of specifications? If you have the old pump's specifications that would be great too.
    Quote Originally Posted by mgill View Post
    1. I assume moving to a straight check valve and removing the old 90 degree one is ok, correct?Yes.
    3. I cant figure out how to cut after the inline chlorinator - I have to cut above it in the line. I can either replace it with a new one or should I consider inserting a salt system at this point? Just take out the chlorinator and put in an equivalent length of pvc. You can always add an SWG later if you want.
    4. Any issues with my idea to insert isolation valves? Sounds like a good plan.
    Mark
    Love TFP? Become a
    TFP Supporter!
    Oct 2007
    Parkland, FL
    752
    Do you mean the spa completely empties? I've had 2 houses with spa's and they always drain down when the pump is off. usually about half way or so.
    Mark
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Apr 2012
    Morgan Hill, CA
    16
    Thanks everyone. A few follow ups:
    For the spa - it just drains down to the level of the jets. Not a complete drain out. I'm pretty convinced that its one (or both) of the check valves in this section of the plumbing I'm about to repair unless someone convinces me otherwise.
    As for the pump change comments from @zea3 here are the links to the specs for the old a new pumps. When the old one seized the pool guy that fixed it swore I should go from the original 2.5hp pump to a 1hp pump to save money. I did it and could barely move enough water to even make the pool viable. After much negotiation he came back out and put in the 2hp pump I have today. When the solar is closed everything is great. The key difference is when the solar valve is open the system is moving water to the roof of the house which is 2 stories high. With the old Hayward pump the spa waterfall worked, after the pool guy switched the pumps the waterfall is barely functional. Did he do something else when he installed? Maybe -- I've got no way of knowing. In hindsight I wish I would have done more research when he did the work but I needed it fixed quickly. Kicking myself for that hasty decision for sure.
    Both are single speed pumps.
    Old pump - Hayward Super II Pump SP-3020X25 - http://www.hayward-pool.com/shop/Pro...03_-1_14002__I
    New pump - Waterway Champion 2hp - http://www.waterwayplastics.com/prod...ion-56-frame3/
    Oct 2007
    Parkland, FL
    752
    For the spa- my new house does that and my old house did that every single night. I'm pretty sure that's normal.
    Apr 2012
    Morgan Hill, CA
    16
    Quote Originally Posted by robl45 View Post
    I am assuming for my pool this is not the case for a few reasons:
    1. For the first 8 years I owned the pool the spa stayed full
    2. I dont understand the value of multiple check valves in the supply line for the spa if they aren't there to keep water in the spa
    3. The top 24 inches of the plaster in the spa is clearly deteriorating from exposure to the air every night. There is one area where the air has corroded a piece of the structure just below the surface and Ive got rust spots now as well.
    Everything Ive got going on here indicates to me that I need to get back to the spa staying full.
