Thread: Pentair Intellichlor IC40 lights stay on after pump shuts off.
    May 2015
    Easton, Ma.
    2
    JCLARK
    I have a Pentair Intellichlor IC40 SWG #520555 and the Power Supply Box # 520556. It always shut off when my pool shut down. Now the lights stay on flash after my pool shuts off..... 3 years old. Version 3.01... New to this site... Hope this works. Thanks in advance...
    18x36 Inground, Vinyl Liner, Pentair Whisperflo 1.5hp Pump, Pentair FNS36 Plus DE Filter, Pentair Intillichlor IC40 SWG......
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Pentair Intellichlor IC40 lights stay on after pump shuts off.
    When you say it "shut off", I am assuming you mean all of the lights went out when the pump turned off.
    And now when the pump turns off, the lights stay lit up. You probably have the Salt light flashing red and green, and the red Low Flow light on and the cell light on or off? and are the output lights on or off?
    Is the pump and SWG both on a timer? Same timer or seperate timers?
    Has there been any work done on your pump or SWG lately?
    It sounds to me as if somehow the SWG has been taken off of the pump timer and put onto a circuit of its own. Now when the power to the pump is off, the SWG is not.
    Divin Dave,
    May 2015
    Easton, Ma.
    2
    Thank you for your quick response... I didn't have my timer switch set up yet. It was in the on position..... All set.....
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    good deal...
    Divin Dave,
