Results 1 to 9 of 9
Thread: Bonding and Corrosion
    Ok, I have a Pool Pilot 75003 Chlorine Generator. I started it today and I am getting a Low Flow, so I checked all the usual issues that can hurt flow and all are ok. I took the cover off the Pool Pilot and noticed that the 838N, 75003 Interface Board on the bottom was very corroded, the board itself the traces, especially the traces and wires that connect to the tri-sensor.
    I then noticed that there is a bonding lug and the unit is NOT bonded. I looked at the installation manual and found that the unit should be bonded to the pools bonding wire.
    1) Can the lack of bonding to the pool pilot cause corrosion to occur within the pool pilot?
    2) I have not done any testing of the tri-sensor yet but I have a lot of green corrosion on the tri sensor plug connector. In the old days on car I used to mix up baking soda and water and pour it on the battery and it cleaned the corrosion right off. Do you think a baking soda solution will clean the corrosion off the connectors?
    Thank you, Mike
    30K Gallons
    Cartridge Filter
    In-ground Plaster
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Bonding and Corrosion
    1. Apparently. I have a new swg en route, and I will make sure it is bonded. The previous one wasn't, and I didn't notice any corrosion.
    2. I can't imagine baking soda and water will hurt anything.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Thank you, i will get the copper and bond mine also. My communication board is badly corroded with green corrosion and the 6 pin on board connector was green corroded.
    I removed the board and cleaned it with a baking soda solution and it cleaned the board up nicely no more green. I will do the same with the plug pins and keep my fingers crossed that it works. Note that it is necessary to tighten the pins in the plug by spreading the pins a bit with a thin blade so they make better contact. Ill post the results.
    30K Gallons
    Cartridge Filter
    In-ground Plaster
    Here is a link to cleaning circuit boards with baking soda
    Http://www.ehow.com/how_6085250_clea...king-soda.html
    30K Gallons
    Cartridge Filter
    In-ground Plaster
    Sorry that link does not work. Search the terms within that link and you should find the article
    30K Gallons
    Cartridge Filter
    In-ground Plaster
    Ok the low flow was caused by green corrosion in the box side of the 6 pin tri-sensor connector. Soaking the board in baking soda cleaned it up nicely but I was unable to clean those connectors well. I cleaned the 6 box side connectors using contact cleaner and a 1/16 inch drill bit. Moving the drill bit in and out of the connector scraping the sidewalls dislodged the green corrosion. This was done by hand not using a drill. Put the board back in and the low flow light was off. I was able to test through this connector using an ohm meter and a spare 6 pin connector from an old trisensor.
    Question what do you think about using dielectric grease on the 6 pins to keep the moisture out?
    30K Gallons
    Cartridge Filter
    In-ground Plaster
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    That was a lot of work! Glad it's all back in working order. I think the grease would be a good idea.
    Moran expert on this, but bonding is typically for safety of stray voltage. Usually very minimal voltage, but enough to cause issues. First discovered on farms where cows were now producing milk because of the minimal shock.
    With that said, stray voltage and lack of good grounds and bonds can do crazy things. I once had a customer who had to copper water mains replaced in 3 years because of pin holes, tons, the stray voltage was going to the water ground then leave ing into earth. The solution was addition ground rods And finding the circuit that had the stray voltage. A lot of times it's the neutral conductor in contact with a ground, after sub panels, where they land separately. Bond the unit and check all
    Your connections for anything that might have a run Mark on the wires or such.
    I worked with an engineer out of CA that does supper high end stage setups and bands for Capital Records. He would explain it and everyone's heads would spin... But it is a possible reason. Weather is another.
    Using Tapatalk
    Auto correct sucks...not Moran, was supposed to say not an expert on....
    Using Tapatalk
