Results 1 to 14 of 14
Thread: 2 week old plaster... CYA at 80... No chlorine levels... High PH
    Mar 2015
    Granada Hills, CA
    29
    So I had the pool plaster guy do the startup the first week... My test kit arrived end of the week but we went out of town for the weekend and I just tested the pool the following week for the first time. Our regular pool guy appeared to SKIP this week too... Complicating matters. The PH was off the charts above 8.2.... The CYA was 70-80. Which I am shocked was so high so soon since I didn't even put in any tri-Chlor tablets yet. Which leads me to problem #3... Chlorine level was basically non-existent. I put my floater in with tri-Chlor today... But I fear using them with the high CYA. My pool does get full sunlight ALL day.. So CYA can be a little higher.
    Today I just added a conservative amount of acid... About 50 fl ounces... To see if I can take the PH down. I was going to add some liquid chlorine too... But read I should add it slowly with new plaster... And some recommended just tablets for 4 weeks. But since my CYA is high and chlorine basically non-existant... I figured adding liquid chorine is better.
    Not sure what type of start up the pool guy did... Imagine it was a traditional start up. Frustrated my regular pool guy decided to skip this very important second week.
    My TA and Calcium levels were 100 and 300... So they both were good at least.
    Any advice moving forward.... Pool and plaster at least looks all clear!
    1961 Lazy-El Pool. approx 30k gallons 20x40.
    Pentair 011018 IntelliFlo Variable Speed High Performance Pool Pump
    Pentair DE Pool Filter
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: 2 week old plaster... CYA at 80... No chlorine levels... High PH
    At this point you can not afford to use any solid chlorine products unless they are calcium based (CalHypo) because you can afford to bring your CH up. I would just stick with liquid chlorine.
    Support the site
    Mar 2015
    Granada Hills, CA
    29
    Any reason my CYA would be so high so soon... No tablets were even put in the pool as far as I knew... Until I put in my floater today for a few hours... Then took it out after I read up on my high CYA.
    May 2014
    Franklin, NC
    9,184
    There is no CYA in tap water, so,I can on,y assume the plaster guy added it during his start up.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    You definitely need to maintain your PH and FC levels. If your pool spends much time with FC level below the minimum level for your CYA level algae will start to grow. Here is the Chlorine CYA Chart. Min is 6 and target level is 9.
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals to maintain it.
    Use PoolMath to determine how much to add.
    Mar 2015
    Granada Hills, CA
    29
    Quote Originally Posted by pooldv View Post
    Thanks, going to add more liquid chlorine tomorrow... Gonna tell the pool guy to not use tablets anymore. I am over trusting a pool guy to maintain my pool... Learned a ton on this site in only a few weeks. Gonna be proactive with my pool this summer and plan on going solo with the pool maintence by the fall.
    I did read something interesting about lowering CYA on another site... They said CYA floats on top of the water-line... So if you pump out water from the surface rather than the deep end... You will get rid of CYA without wasting so much water?
    Haven't heard this anywhere else... Any truth to it?
    DFW, TX
    24,468
    I haven't heard that before either.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That is absolutely not true at all. You cannot remove Cya by skimming the water's surface. Cya becomes dissolved, and it does not ride at the top of the water column.
    It's creative..but untrue. Funny, they probably believe it stays at the top, creating a "shade" for the Chlorine. Amusing.
    Essential Links:
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    At zero, you probably need 3 gallons of 8.25% to get it to target on a 40,000 gallon pool. Run the numbers in pool math above.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    Quote Originally Posted by rmm221 View Post
    I'd tell the pool guy to take a hike now...many are notorious for leaving you when you need them most.
    32 x 15 15500 gal. IG gunite, 6 ft. round attached spa, diamond brite 2 plaster, flagstone coping w/concrete spray deck, IntelliChlor IC-40 SWG, 2 hp Max-E-Pro pump, 450 sq.ft. System 3 cartridge filter, 400k Max-E-Therm NG heater, automation is IntelliTouch i7+3, Polaris 280 pressure side cleaner,
    TS 100, Borax
    Mar 2015
    Granada Hills, CA
    29
    Well, I think I got things under control quickly thanks to all your help and pool math. I also re-tested the CYA in direct sunlight... Since seeing that little black dot is a little subjective... I tested it again and found my CYA to be 50. So I didn't over do the chlorine to much with the new plaster.
    FC - 4.5 ( up from 0)
    PH - 7.5 ( down from 8.4)
    TA - 90 (down from 100)
    CYA -50 (first trading was 70-80 in shade)
    CH -250
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Direct sunlight as in your back to the sun and holding the test at waist level, right?
    Before I read here that was the proper way to test for CYA I would just hold the tube in direct sunlight thinking
    the lower reading was correct.
    Dolphin E10 Cleaning Robot.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    CH -250
    Now you just need to wait for the water to warm up!
    When I add bleach, I just lean out as far as I can and pour it in front of the return stream. Sometimes you can even see the yellow cloud spread and dissipate. It's a couple feet away from the plaster in all directions. Same with acid. And if you're really worried, dilute the acid with a bucket full of pool water before you pour it in. I don't bother anymore myself, because that's just more fumes to choke on.
    Mar 2015
    Granada Hills, CA
    29
    I'll do the CYA test again tomorrow with my back to the sun.. I was holding it at waist level... but it might have been in direct sunlight.
    We actually took a short dip in the pool this past Sunday when it was 80s in the Valley. Looks like it's cooling off again and we are getting some much needed rain in So Cal by the end of the week... so probably no pool this weekend
