Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Super Concentrated Clarifier
    May 2012
    Dallas, Texas
    47
    My parents gave me a bottle of hth super concentrated clarifier; active ingredient: cationic polymer. My water is a little cloudy. What does this stuff do, and is it ok to use. The bottle advertises improved filter efficiency and crystal clear water.
    Current levels:
    FC 9
    pH 7.2
    TA 100
    CYA 20
    15,200 gallon 24' X 52" round AG; installed 2011; SWG
    1 hp Dynamo pump; Pentair Meteor sand filter, 2.1 sq. ft. filtration area, 42 GPM flow rate
    TF 100 Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Super Concentrated Clarifier
    It makes particles attract to each other, stick together, and fall to the bottom. If...you dose it precisely, have the correct type of particles, and all other conditions are perfect for its use. If you don't know the answer to all those questions, I'd suggest not using it. It could make things worse.
    Why do you think your water is cloudy, and why is your FC so high right now? It's over rage for your Cya by a good deal.
    Essential Links:
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Agree with Patrick!
    Plus, what is your CH and how have you been chlorinating?
    Support the site
    May 2012
    Dallas, Texas
    47
    4 weeks ago I started adding chlorine because it was green with leaves on the bottom and had mosquito larvae in it. I started SLAM 2 weeks ago because the water was still murky. I have kept the FC up since then. It is much better now, I can see the bottom well but it is still not crystal clear.
    Current CH is 100.
    Chlorinating with bleach.
    TF 100 Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Ok,
    I would stick with your SLAM procedure. Stick with it until you pass all criteria to be finished. Are you currently following SLAM, and how is that going?
    Essential Links:
    May 2012
    Dallas, Texas
    47
    Yes, still following SLAM, it's going good, the water is clear but slightly dingy. I've seen great progress in the last few days. Chlorinating using 30 ppm CYA level.
    TF 100 Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Ok great!
    No need for anything else. Just time, filtering, and free chlorine is all you need.
    Essential Links:
    30,403
    Great advice!
    Are you also keeping up with your filtration and vacuuming?
    May 2012
    Dallas, Texas
    47
    The filter has ran 24/7 since April 13, 2015. I vacuum every two to three days and brush daily.
    TF 100 Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Can you post some current test results so we can better see where you are?
    Essential Links:
    May 2012
    Dallas, Texas
    47
    Current Levels 10:00pm
    FC 5
    CC less than 0.5
    pH 7.6
    TC 100
    CYA 40
    CH 100
    The water is quite a bit better. Clear but not crystal clear. Now that I can see the bottom better, I am noticing that there is something that resembles filter sand gathering in the bottom of the pool a within few hours after vacuuming. It is a gray color sand or sediment. The filter sand has not been changed since install.
    TF 100 Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Ok, I'm not sure how you are in your other aspects, like the OCLT in SLAM, but your FC is too low for a SLAM value based on your Cya. It doesn't sound like you passed the SLAM. If it's been low like this before you finished, you still need more SLAM and filter time. Sand very, very rarely needs changing. At most your filter may need a deep cleaning, but post back about where your SLAM has been in the last week or so.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Quote Originally Posted by Toomchfun View Post
    That sounds like dead algae to me.
    http://www.troublefreepool.com/conte...f-pool-filters
    May 2012
    Dallas, Texas
    47
    SLAM was in progress until 5-13-15. Then the water was clear, OCLT resulted in FC loss of less than 0.5 and CC was at or less than 0.5
    The results were the same on 5-16-15.
    I added chlorine today to bring the FC level up to 16ppm and will re-test tonight and in the morning for OCLT. I will post results and pic of water tomorrow.
    Thanks for the help, I really appreciate it.
    P.S. I have pics through out the process of cleaning if needed.
    TF 100 Test Kit
    May 2012
    Dallas, Texas
    47
    My results from last nights test seem to be tainted. At 9:30 pm I added chlorine to bring the FC level up to 16ppm. I tested at 10:30 pm and the result was 15.5 ppm FC. This morning at 6:15 am FC was at 16.5 and CC was at or less than 0.5.
    I will conduct another OCLT tonight, meanwhile I will keep the FC at shock level, testing and adding more on my lunch break and thru the evening.
    Attached are pics of the water from yesterday after vacuuming.
    TF 100 Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That's just testing/sample size variation. Possibly mix time added in, but no worries, the difference isn't enough to be concerned about.
    Essential Links:
    May 2012
    Dallas, Texas
    47
    OCLT from last Night:
    9:00pm FC 16.5
    7:00am FC 15.5
    TF 100 Test Kit
    May 2014
    Franklin, NC
    9,184
    9:00pm FC 16.5
    7:00am FC 15.5
    1ppm, a Pass
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey congrats! Good work...
    Essential Links:
  20. Back To Top    #20
    May 2012
    Dallas, Texas
    47
    Thanks for the help! You guys are awesome!
    TF 100 Test Kit
