Thread: Need to know if I add chlorine when My CYA is 20. 0 chlorine. opened pool today.
    Apr 2015
    Wheelersburg, Ohio
    17
    Thought I had to get my cya up first. Do I add chlorine or wait.
    In ground, oval shape, 18'X36',23,800 gal., vinyl liner, 1.5HP Hayward,super pump, Hayward tank/ sand filter/ TFP 100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Re: Need to know if I add chlorine when My CYA is 20. 0 chlorine. opened pool today.
    Quote Originally Posted by Bevly View Post
    Your pool needs to ALWAYS have above the minimum FC level for your CYA. Whatever that CYA level is. Even if it's zero, you need some chlorine in the water. Chart
