Thread: Safe to swim after muradic acid?
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    I add my MA in front of one of my Swim Jets. This is essentially a large air siphon jet driven by a 3hp pump. The huge circulation it offers means I can be back in the pool sooner. Is there any negatives in adding to this heavily aerated water flow? It is not a splash hazard as the turbulence is fare enough below the water.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Safe to swim after muradic acid?
    No problem. That is the best way to add it. 15 min or less and good to go.
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Thanks pooldv. Good to know this doesn't have any undesirable side effects.
