Results 1 to 8 of 8
Thread: Calculating Volume in a customr shaped pool
    May 2015
    San Diego, CA
    3
    I am in need of help calculating the volume in our custom shaped pool here at the hotel I work for. I've calculated it myself but it was a real pain to do so and I am not supremely confident in my math. The pool & hotel are going on 25 years old and past stated volumes I've found in the records seem suspect and there are several different #s so the only way to know for sure is to recalculate it. I've attached a drawing I did showing the shape and measurements I made myself. Can anyone calculate it and tell me what you get so I can compare it to what I got?
    I appreciate any help you can provide!
    Mark
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: Calculating Volume in a customr shaped pool
    The easiest way to calculate is by using a fas-dpd test. Using a 25ml sample you can test to within .2 ppm. Make a chlorine addition using pool math here, estimating your gallons, from what you got to a target number.............retest...........and see if it is high or low. You can get within 500-1000 gallons or so which is close enough.
    May 2015
    San Diego, CA
    3
    Quote Originally Posted by woodyp View Post
    You can calculate pool volume(total gallons) with a DPD test? I've never heard about that. Are we talking about the same thing or is it possible you misunderstood my question?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I see about 68000 gallons breaking it up into circles and rectangles and half-circles. You did an excellent job with the scale. I used paintshop to draw the circles and the relative dimensions were darn close!
    What Woody is talking about is using poolmath. If you plug in 68000 and go about treating the chemistry that way, it shouldn't take long to see if you're overshooting or undershooting consistently. That applies to everything. Not just chlorine, but also TA & pH. Between the calculator and Effects of Adding Chemicals down at the bottom, within a few additions you should know roughly how much you're over or underdosing. So you adjust the volume at the top of poolmath up or down. Just keep raising or lowering the volume until you get it bracketed and then narrow the gap. It will take a while, but the point comes when you hit your target every single time you add something. That's when you know the volume.
    Apr 2010
    East Texas
    9,572
    What ^^^^Richard^^^^ said.
    FAS-dpd test. Drop based.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Or you can calculate the volume by using the TA or Muriatic Acid method.
    Have fun with this one!
    http://www.troublefreepool.com/threa...ng-Pool-Volume
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Wow Zep! That is a LOT of pool.
    Welcome to the forum...we really want to see this one for sure.
    Essential Links:
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Better not let Jerry Brown see that thing. He might try to use it for as a new found water source.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
