Thread: green pool and filter problems
    May 2015
    prattville, alabama
    1
    The pool is green we have put in 6 ounces of swimtrine and then doubled shocked for the past 3 days brushing it last 3 days. Jst bought a new haywood motor and new multi port valve. When backing washing the pool do not see any green coming out of the hose just clear water any idea why I am not seeing green coming out of the hose
    The pool is a 16/32 in ground pool chlorine. It has a haywood 1hp motor and a s220t sand filter all haywood equip.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: green pool and filter problems
    Hi, welcome to TFP.
    I don't know what swimtrine is, it is not one of the recommended pool chemicals for TFPC. TFP recommends that you buy a really good test kit and maintain your own pool with inexpensive chemicals based on those test results.
    Here is a discussion of Test Kit Comparison. I personally use the TF100 from tftestkits.net.
    Here are some intros to the basics
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals to maintain your pool.
    Use PoolMath to figure out how much to add.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum!
    What does double shocked mean exactly??
    Essential Links:
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    It's Taylor time
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
