Thread: Combined Chlorine question
    May 2015
    Albuquerque
    1
    So I've read so many posts already about this problem but still not entirely clear on it. I'm using a Taylor test kit from Leslie's and the DPD reagent tests showed significant CC so I shocked using potassium peroxymonosulfate and ran with cover off during a sunny day. FC DROPPED FROM 3-6 to 0.5, but the CC test was still at about 10 PPM. I read in one post that my use of non chlorine shock might "register" as CC in the testing, so if that's all that's happening I'm fine with it.
    My first attempt a few months ago at "super chlorination" was an abject disaster that led me to drain the 450 gallon spa and start over, but I am really interested in learning how to make this spa set properly using 7.86 bleach I also had to put in 1/4 cup muriatic acid to get the Ph down to 7.5 in this process (down from 8.2+) and I keep struggling with rising Ph numbers pretty much each day.
    At present my FC is at 1-2, but my CC is testing at brighter than my 5-10 scale shows on the kit, so something is going on. Ph is climbing back toward 7.8 as well, so any suggestions would be appreciated. My test kit doesn't allow for testing CYA but a "test strip" showed values of below 40 CYA. NOt sure that's reliable since it also showed low Ph and 0.5 FC, though.
    TL DR: can't tell if my very high CC reading in spa is just potassium peroxymonosulfate or if not how to solve my CC PROBLEM
    If my signature isn't below I still have to figure out that also but it's my first post
    20,000 gal 40 x 14 oval gunite pool with UG piping, Hayward Crystal Clear II D.E. Filter (flow rate 96 GPM / Max 50 PSI); Hayward sel priming Super II with 1 hp. Inground Gunite/tile spa (~450 gallon) with Raypak (Rheem) gas-fired Pool & Spa heater model 406A w/ 399K BTU. Spa pump 3/4 hp Sta-Rite Dura-Glas P2R5D w/ Jet 2 hp Franklin Electric 1081.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Combined Chlorine question
    Welcome. Someone should be along shortly to answer your question.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    MPS reads falsely as CC. Taylor sells a special reagent for it. http://www.taylortechnologies.com/Ch...P?ContentID=24
