Results 1 to 12 of 12
Thread: problems with Hayward filter
    May 2015
    youngsville
    9
    I'm new to the pool world. The pool has been a swamp for 2-3 years. On April 23 I dropped 12 Lbs. of dichlor in the pool. Then noticed my polaris picking up sand so I changed the sand and a busted lateral(sand from home depot). I'm thinking this sand was a mistake as it is not removing anything from the pool running 24/7. Days go by with no PSI change. I have tried adding DE and I get a rise from the DE but nothing after that. Earlier today I vacuumed the floor blind and the pressure got up to 30 by the time I finished. I figured I would let it run like that for a little bit to try the dirty filter cleans more idea and when I went back to check it out about 20 minutes later the PSI had dropped to 24. All I can assume is that the dirt/Dead algae is passing through the sand and back into the pool. I know I'm probably forgetting stuff.
    Any help or ideas would be greatly appreciated. I have been reading about putting pea gravel in the bottom of the filter and also debating on changing to a different sand. Any insight on these would be great also.
    Ch 100
    tc 3
    fc 3
    ph 7.5
    ta 90
    cya 50
    1st picture is after 12 Lbs of dichlor
    2nd picture is current
    Thanks Ben
    20 x 40 IG vinyl 30k gallon
    Hayward S244T300Lb sand filter, 1.5hp Super Pump, polaris booster for 280
    Aquarite SWG
    T-100 test kit W/ Speedstir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: problems with Hayward filter
    Welcome to TFP!
    If you are sure things are still getting through the SF, you still have a problem with a lateral or similar as before. Are you sure you replaced with the correct type and amount of sand?
    Where are those test results from? If from your own kit, can you tell us what type of kit you have please?
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Welcome to TFP!
    Here is a post with nice details on sand filters that should help. http://www.troublefreepool.com/threa...-a-Sand-Filter
    As for your green pool, SLAMing Your Pool is what you need to fix that.
    Read this Test Kit Comparison and get one. I use the TF100 from tftestkits.net.
    After you SLAM your pool and fix your filter here is more info from Pool School about managing your water
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals to maintain your pool.
    And use PoolMath to determine what to add.
    30,432
    I do not see your filter as a problem. Your pics are indicative of a typical algae laden pool that needs to be SLAMmed and it will clear up
    May 2015
    youngsville
    9
    I forgot to mention that I did slam the pool between these pictures for 8 days with 20+ppm FC, the only reason I let the chlorine come down was to check the PH. After a little looking around I found that the quikrete pool sand from home depot is 20-40 (.425mm - .85mm). So I did another sand change, this time to hth brand #20 silica sand. I checked over the laterals again and they are fine. I'm using the aquacheck 7 way or the HTH 6 way test strips because its all that I currently have.
    Aquarite SWG
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Glad you changed out the sand for #20 silica. Pools like this take a while to clean up.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Quote Originally Posted by lillbro11 View Post
    Welcome to TFP!!
    You really need one of the recommended test kits. To effectively practice the TFPC methods, the FAS/DPD chlorine test is essential. All the kits on the list contain that test while very few other kits do. The kits sold at the pool store generally won't won't cut it, but be careful pool store employees are known to say “it's the same thing”. Strips just do not provide the accuracy you need for a SLAM
    Support the site
    May 2015
    youngsville
    9
    I have the FC at 20 again. TF-100 comes in tomorrow.
    Aquarite SWG
    May 2014
    Franklin, NC
    9,197
    great, I think that will help you clear it up. With strips you really don't know if it's 20 or not.
    Support the site
    May 2015
    youngsville
    9
    5:00 pm yesterday
    FC 12
    8:00 this morning
    FC 28
    I poured a little extra bleach last night when it started to rain.
    Aquarite SWG
    May 2015
    youngsville
    9
    7:30 pm
    FC 29
    I removed my light from the niche and cleaned it the best that I could. Should I leave the light out or replace it into the niche?
    Aquarite SWG
    DFW, TX
    24,513
    If there is still algae in there then keep scrubbing every day until it is gone.
