Results 1 to 8 of 8
Thread: Just got solar not sure about auto pump
    jgjh151's Avatar
    May 2012
    Glenville, NY
    39
    We just had a solar panel system put in, the thermal panels that water goes through, not the home solar panels. It has an automatic valve and all that, but I have to manually turn on the pool pump for circulation into the system. This doesn't seem optimum to me. Am I right in thinking I need an automatic timer for the pump to kick on and off? Would I just set the automatic timers to go on during the high sun hours while I'm at work then kick it off in the afternoon? Or is there something I should look into that connects to the solar controls that turns the pump on when the solar thermometer tells the solar system to be in use? I don't understand how this should be working.
    Jon
    21,000 gallons, Hayward sand filter, IG, 16x32 kidney, Vinyl, Hayward Super Pump 1hp, Flow rate: ?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Just got solar not sure about auto pump
    If you tell us the exact equipment you have (which brand and type solar controller, type of pump, etc.)we can give better advice, photos help too.
    jgjh151's Avatar
    May 2012
    Glenville, NY
    39
    Jon
    jgjh151's Avatar
    May 2012
    Glenville, NY
    39
    Jon
    jgjh151's Avatar
    May 2012
    Glenville, NY
    39
    Hayward filter and 1.5hp pump, gold line control for solar temp. Currently just on/off switch for pump.
    Jon
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The GL-235 controller you have will support both pump control by timer operation, as well as pump override application depending on how it is connected, all you need is a timer.
    timer control operation means you will only get solar heat if the controller sees heat is needed and available while the pump is running on timer
    timer override control means the GL-235 can bypass the timer and turn on the pump any time heat is needed from the panel and heat is available.
    For most basic timer systems we tend to suggest Intermatic brand mechanical timers, they are rugged and are not prone to being zapped by power surges like the digital timers are.
    jgjh151's Avatar
    May 2012
    Glenville, NY
    39
    With basic Intermatic brand mechanical timer, I can do either way (time/timer override) or would I need a different timer depending on what I want to do? Realistically I'm not sure I'd need override if I just let it run while I'm at work.
    Jon
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You could do either, it depends on how the GL-235 is wired, instructions are in the GL-235 controller manual available online as a pdf https://www.hayward-pool.com/pdf/man...olarGL-235.pdf
