Thread: Newbie with Numbers
    May 2015
    Southwest Florida
    3
    Newbie with Numbers
    Hi all, I've been reading TFP for months now and have learned a lot. We are renting our home and the owner was using pucks so the CYA is very high. I've stopped using them but a drain/refill is not possible so we'll have to work with what we've got. Right now the pool looks great after it started to turn due to low chlorine and the pump loosing prime when we were not home. I purchased a Taylor test kit and here are my results.
    FC = 12.5
    CC = .5
    PH = waiting until FC is down to test but it has been on the high side in the past
    TA = 160
    CH = 310
    CYA = 100+
    Water temp is about 80 right now and will get warmer, full sun in southwest Florida. Pump with water feature runs about 8 hours a day.
    I also purchased 25# of boric acid that I will be adding once everything is in check.
    In ground caged pool aprox 12x24 plaster with cartridge filter and water feature.
    May 2015
    Southwest Florida
    3
    Re: Newbie with Numbers
    Photos taken today of the pool showing water crystal clear and the water feature.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Looks great. I am guessing your PH will be high once you can test when the FC falls below 10 since you have such a high TA.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    If a partial ....."drain"...........is not possible. How about a partial ...."overflow"?<<<<<..NOT good advice by the way!!!!!......but interested to know why a partial drain is not possible. Hopefully you will get enough rain water down there and pumping it to waste will help dilute it.
    May 2015
    Southwest Florida
    3
    Right now I am able to replace a couple inches a week due to evaporation, once we start swimming more there will be splash out from the kids and yes overflow once the summer storms kick in. I let some out here and there when I can.
    Will adding MA help lower the TA? I'm sure the PH is high too so it can't hurt, right?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    CYA does not evaporate, so that won't help. The real issue is what is the real CYA level. 100 is max for the test so it could be 200 or 300. Need to do the diluted test. The reason you need to know the real CYA level is because you need to chlorinate based on that according to the Chlorine CYA Chart
    http://www.troublefreepool.com/threa...Kit-Directions
