Results 1 to 9 of 9
Thread: Using Tricolor to Raise CYA?
    Jul 2014
    Frankfort KY
    6
    Hello all!
    This is the first question the search bar has failed me on, so here it goes:
    If my CYA is low, and I am using Trichlor to raise both FC and CYA, does the CYA reading happen quickly, or is it the same week long wait as if I had hung the stabilizer in the return with the sock method?
    PH 7.7
    FC 1 (oops) CC .5
    TA 90
    CH 160
    CYA 20
    Borate 30?
    salt 780
    Added 14oz of Trichlor after this reading. Pool math says that should raise the CYA by 3.1
    So I am guessing by adding another 28oz of Tricolor, as the FC needs to be raised, I will then be at a CYA of 30.
    I ask, because I have added Tricolor a couple of times, and I don't see the CYA increase PoolMath says I should see. My notes say I added 40oz of Tricolor on 4/18 when I had a cya of 25.
    19K gal, IG, 16x32 vinyl, sand filter and 1HP pump look like Hayward models, on an Intermatic timer.
    Testing with K-2006, LaMotte Borate strips, Aqua Check salt strips to fill in all the spaces in Pool Math!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Using Tricolor to Raise CYA?
    It can take some type, Chemgeek has posted the chemcial process before and it does involve multiple steps, but I have not seen a timeline on how this compares to dry CYA. Are you sure you don't have a water leak which may be lowering your CYA through dilution from fill water?
    30,432
    First, I will say that pucks are generally not the best way to raise CYA. It is most always more precise to add the CYA seperately in a measured dose.
    That said, the CYA will register on your tests once the pucks are dissolved.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    I'd go with pure cya granules from Wally World. Save the pucks for vacation and times away.
    Jul 2013
    Waxahachie, Tx.
    448
    Trichlor will also lower your PH, so it's marginal already, now you have 2 issues to deal with.
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    You can use Pool Math to determine just what each puck would do to your water balance. I sometimes use them so I have written on the top of the container just what each puck will do in my volume of water.
    In my case:
    Trichlor
    1 puck = 7.2 oz.
    FC +2.5
    CYA +1.5
    pH -.14
    salt +2.1
    chiefwej
    Jul 2013
    Waxahachie, Tx.
    448
    Good idea. I do have a few dichlors for quick emergency uses. Only time i used them was last year for initial start up
    Jul 2014
    Frankfort KY
    6
    That is a good thought, but I do not believe I have a leak as I have not had to add water yet.
    Jul 2014
    Frankfort KY
    6
    I think I am messing up the respond thing, sorry guys.
    I do have some pucks that I have slated to keep snakes out of my wood pile.
    The Triclor is from a purchase I made before I found TFP.
    My PH is trying to creep up due to being covered I think. Either way, the change in PH from the Trichlor is ok in this case.
    I have some of the CYA Granules, I put in a bottle and a half last year because I did not realize how long it would take to dissolve. Also before I found TFP.
    Did i mention I love TFP?
    It is great to know if I find something mundane, or truly weird someone else has seen it or heard of it, and i can avoid it.
    Thanks everyone!
