Results 1 to 8 of 8
Thread: question cya
    Jul 2014
    Lancaster PA
    24
    question cya
    after fighting with high cya last year well now i got it to less then 20 cya. I have some bioguard clc3 left over and was wondering how much of that to increase my cya by 30? Figure now is the time to try and use it since it is mostly useless.
    Thank you
    Shawn
    Thank you,
    Shawn
    Pool - AG 12000 Gallon 14 years old
    Hayward Xstream CC1500 with the same pump that came with it.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: question cya
    http://www.troublefreepool.com/threa...orine-question
    Theres a quick read thread for you. No CYA in it!------chlorine combined with calcium. You got high CH?
    Jul 2014
    Lancaster PA
    24
    Re: question cya
    no problem is my cya is below 20 now so need to increase it and wanted to use the clc@3 instead of just my liquid chlorine . i need the cya added!
    Thank you,
    Shawn
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: question cya
    You cannot increase CYA with chlorine, si am not understanding. If you want CYA increased then use granular stabilizer in a sock and set it in the skimmer or tie it in front of the return jet.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: question cya
    CLC is Cal-Hypo so does not raise CYA, only raises CH and FC, note you should be particularly careful with it as it will react explosively with dichlor or trichlor (which do add CYA in addition to FC)
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: question cya
    Quote Originally Posted by jsbleacher View Post
    Bioguard CLC 3 does not contain CYA, it contains calcium - it's CalHypo.
    You need to go,by WalMart and just pick up a bottle of granular stabilizer and add it via the sock method. Pool Math will dertemine the amount you need to add. Rather than adding it all at once, break it up into two additions so that you can test before you make the final addition. Differences on pool volume may cause you to overshoot if you do it all at once.
    Support the site
    Jul 2014
    Lancaster PA
    24
    Re: question cya
    **** **** sorry
    Thank you,
    Shawn
    May 2014
    Franklin, NC
    9,184
    Re: question cya
    **** **** sorry
    nothing to be sorry about. The chemical companies make up fancy names for their products to confuse people.
    Support the site
