Results 1 to 9 of 9
Thread: Adding Borate, why muriatic acid ?
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    Question Adding Borate, why muriatic acid ?
    Hello,
    I decided adding borate to my pool, but why adding muriatic acid? Why not sodium bisulfate?
    Muriatic acid is hard to find in my region...
    Thanks !
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: Adding Borate, why muriatic acid ?
    Yes, you can use it. Muriatic acid is usually cheaper to use. Check the paint and hardware stores?
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    Hello,
    I finally found muriatic acid, but it' sur not cheaper here.....
    For my 45 000 liters pool, for each add of 2 kg of borate, i must add 1 liter muriatic acid, or 1,2 kg dry acid.
    Dry acid cost 8$ for 3 kg
    Muriatic acid cost 6,50$ for 1 liter
    Muriatic is more than 2x expensive here.....
    Bye
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That's unfortunate. Muriatic has less side effect, meaning dry Acid adds Sulfates. Undesirable because it can add to scaling with Calcium Sulfate type scaling, and although unusual, it can come out of solution and crystalize. There was recently a post about just this thing happening. Maybe it's a Canadian thing, but MA is plentiful here, and cheaper than dry acid when you run the numbers on it for a source of pH control.
    Essential Links:
    wjr75's Avatar
    Jun 2013
    IL
    836
    Boric acid pellets from Duda Diesal is the way to go if you could have gotten it. Don't need to deal with the muriatic acid after adding.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    Quote Originally Posted by wjr75 View Post
    I don't know Duda Diesal ....
    Sorry for my english, je suis francophone
    I live in north, no ice in my pool since may 1 !
    Stylus aboveground swimming pool 45 000 liters
    18' round and 52" high with sand filter
    Sep 2014
    Bakersfield, CA
    155
    http://www.dudadiesel.com/search.php...ic+%2Bgranular
    You don't need to use mutriatic acid if you add the borates via boric acid rather than via borates.
    Maybe Duda Diesel ship to Canada?
    Cheers, Peter
    20,000 gal, 52'x17' kidney shaped IG, Pebble Tec, IntelliPro P6E6VS4H-209L pump. Intellichlor IC40 SWG.
    300 sf Sta-Rite System 3 cartridge filter. Poolvergnuegen 4-wheel suction pool cleaner. TF-100 test kit.
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    Finally i found muriatic acid more cheaper.
    4 liters for 9.99$
    Finally my pool reach 30 ppm of borate
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    Just found it at hardware store, half-price the pool store!!
