Results 1 to 11 of 11
Thread: New Build in North Texas - 1st quote
    May 2015
    keller
    129
    EXCAVATING $2,000.00 DOES NOT INC. ROCK HAMMER IF NEEDED
    SHUTTLE $1,800.00 INCL. BOB CAT DIG AND 2 HOURS OF PREGRADE
    STEEL/REBAR $2,200.00 3/8 ON 8" CENTERS (EXTRA STEEL IN DEEP END WALLS)
    PLUMBING $3,400.00 70FT. RUN FROM POOL TO EQUIPMENT ALSO INCL. AUTO FILL
    GUNITE $6,000.00
    COPING & TILE $3,000.00 UPGRADED LUEDERS STONE AND STANDARD TILE
    RAISED BEAM $2,050.00 14' @ 18" & 14' @ 12" & 14' @ 6" ALSO INCL. 2 18"SHEER DESCENT
    DROP DOWN BEAM OF POOL $1,900.00 47' @ 2' WITH CAP
    RETAINING WALL $1,300.00 30' @ 2' TALL WITH CAP
    FLAT WORK $4,250.00 INCL. 850 SQ. FT. BROOM FINISH
    CONCRETE PUMP $650.00
    CONCRETE OVERLAY $2,800.00 CLASSIC TEXTURE (ANY COLOR) 850 SQ. FT & 200 FT. ON PATIO
    PLASTER $2,600.00 GREY PLASTER
    EQUIPMENT $4,600.00 INCL. 580 CART. FILTER , V.S PUMP, POLARIS 280 , 2 WHITE LIGHTS, PL4 REMOTE, CLEANER PUMP, POLE, BRUSH, NET, ETC.
    ELECTRIC $1,200.00 50' HOME RUN INCL.
    CLEAN UP $1,000.00 ALSO INCL. FENCE REPAIR
    MASTIC $600.00 INCL. AROUND POOL AND BETWEEN PATIO AND POOL DECK
    START UP $300.00
    SPRINKLER REROUTE $1,600.00
    DECK DRAINS $850.00 IF NEEDED
    PERMIT AND POWER COMPANY $925.00
    SUBTOTAL $45,025.00
    BUILDER FEE $10,500.00
    TOP SOIL $650.00 2 LOADS DELIVERED AND SPREAD
    TOTAL $56,175.00
    Thoughts? This is MORE than I hoped to spend. Please let me know if there is additional information not listed above that would be helpful to know or understand.
    May 2015
    McKinney, TX
    12
    Re: New Build in North Texas - 1st quote
    What size pool are building? Are you putting in a spa? I just got my first bid yesterday and my cost is just about $2K higher.
    Obtaining estimates for 14,500 gal, IG, plaster, Pentair Clean & Clear Cartridge Filter, Pentair Intelliflow VS Pump, spa, undecided between Nature 2 Fusion and SWG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    That looks pretty good. Let's see what the others say.
    May 2015
    keller
    129
    Quote Originally Posted by melrichardson View Post
    No spa. Straight line pool almost 20k gallons
    May 2015
    McKinney, TX
    12
    ok mine is over 14K gal but with a spa and about 700sq ft of decking
    May 2015
    keller
    129
    are you putting in a spa?
    My quote is using regular plaster with a grey die - no upgraded aggregate or anything.
    May 2015
    McKinney, TX
    12
    Yes, we will have a spa. regular plaster but we are upgrading to quartzscape for $1500.
    May 2015
    keller
    129
    I have another builder coming out Friday. I am all about these guys making money but I find it interesting that there is a line item for the "builder fee" when, at least I believe, each line item has profit built in. For example, two load of top soil delivered and spread for $650? I can fit a few square yards in my truck for ~$20 per yard.
    May 2015
    McKinney, TX
    12
    It is good you are getting that sort of detail on your bid. I have a spreadsheet that will allow me to do a side by side comparison. My co-worker gave it to me to use and he found it on a blog. I would attach it for you but I don't see where i can attach a document in a thread i didn't start.
    May 2015
    keller
    129
    I will send you a pm
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Have you seen pools with a grey dyed plaster? I ask because the finish will not be uniform in color and some don't care for that. It will likely have mottling (from some to a fair amount).
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
